The Saga of Truck Norris
Featured Build Threads
Li'l Work Truck
Enthusiastic enthusiasm enthusiast
GMRS Radio License
Pendleton
SC - USA
Vehicle
Drive
2WD
2.3L
Total Drop
235/70 R15
Complacency is the key by which tyranny opens many doors.
@Rick W asked me why I hadn't started a build thread. Originally, I figured this was just maintenance, but looking at my home gym turned Rock Auto receiving dock, the multiple auxiliary lighting systems, OEM+ stereo build, and probably a plethora of other things I plan to do, I might as well start one here. The name Truck Norris was given to my Ranger by my wife, who says its full name is Truck Norris, Texas Ford Ranger. Why not? Below is a rundown of tthe truck, the status, etc. I know a few people already know this.
Truck Norris, 2008 regular cab, 6' bed.
Drivetrain:
  • 2.3L (171,000 miles)
  • 5-spd, 2WD, 3.73 open diff
Suspension:
  • Coil spring front suspension
  • HD uprated springs per VIN
Goodies:
  • Vinyl 60/40 split seat
  • Rubber floor
  • Manual windows - not a Windows manual. That's something else entirely
  • Bed box
  • Cheapie but cool-looking brush guard
  • Bedlinerish
  • Tinted windows
  • 15x8" Ultra mod wheel
  • Trailer hitch
And that's where that stops. I got ripped the 🚒 off. New to Rangers, didn't know to look in specific places for things other than what I found in a few searches, so I didn't know that:
  • The suspension is done. All the bushings are shot. It's not just old, but dangerously out of alignment, with most of the alignment plates missing, because until a few days ago, I didn't know what alignment plates were. The truck drives fine until you get to 55-60, and because I have no other choice but to drive it, I keep it under 60 and only drive it when I have to.
  • The light for the driver's side airbag will just stick around sometimes (recall fixed, will warranty claim). Figured that's why he left a picture of his girlfriend tucked in the cluster just so.
  • The transmission shears in all 6 gears.
  • The engine was cleaned to remove any oils. Found out the rear main and crank leak, and the valve cover gasket leaks.
  • The steering rack is shot.
  • The clutch master leaks.
  • Belt squeal after a month in requires troubleshooting.
  • Truck has a small coolant leak.
  • The 3/4 spare is off of some front wheel drive car. Not sure if the center bore even matches the truck's.
I'm a FWD guy. Most of my experience has been with Festiva/Aspire, Fiesta ST, Fiat 500 Abarth, and MINI Cooper S, so I knew I was stepping into relatively unknown territory. I didn't know that I was going to get a crash course in truck repair, but here I am.
So! Here's the list of things to address...
  • Suspension
    • Front coils
    • Front upper & lower control arms
    • Front bushings
    • Front shocks
    • Front LCA to sway bar links
    • Camber bolts
    • Rear springs
    • Rear shocks
  • Steering
    • Steering rack
    • Steering pump & hoses
  • Engine
    • Valve cover gasket
    • PCV replace
    • Oil catch can
    • Crankshaft seal
    • Timing chain
    • Coolant pump
    • Upper and lower rad hoses
    • Rear main seal
    • Engine mounts
  • Transmission
    • Rebuild transmission
    • Replace clutch (stg 1? 🤔)
    • Rebuild rear axle?
    • Upgrade from open diff?
    • Transmission mount
  • Body
    • PDR
    • Remove & reapply bedliner
    • Minor touch-ups
  • Cab
    • Update to LED lighting
    • Add under-dash accent lights
    • Fix/swap seats
    • Install stereo
    • Install sound mat
    • Customize bezel
    • Install GMRS radio
    • Install Sickspeed shift knob
  • Lighting
    • LED indicator upgrade
    • Digital flasher upgrade
    • Add under-hood service lights
    • Truck box light
    • Trailer hitch light
    • KC Daylighters for brush guard
  • Misc.
    • Replace spare
    • Line bed box w/carpet
    • Detail, paint correction, ceramic coat, polish wheels & box
    • Debadge tailgate, install new RANGER sticker.
    • Tires
    • Alignment
That should keep you busy for a few munutes.
By the way. "Rear main seal" is rear crankshaft seal. So, when you say "crankshaft seal", are you being redundant or referring to the front crankshaft seal?
I was referring to the front crankshaft seal. I always just knew them as "rear main" and "crankshaft" seals. I suppose it makes sense to call it what it is.
That write up is fantastic! I think if I started with that kind of inspection and detail when I started on mine, they would’ve never been done. Mine was more “fly by the seat of your pants,“ except, with my health issues, it was more like “drag your ass on the ground“ as it went down. And it’s still ongoing.
Thank you for the reference for motivating you! Now, in keeping with the bond of friendship in this group, let me whip on you because “no good deed should go unpunished!”
Pictures! Pictures! Pictures! I, and we all, live for the pictures on this site.
I already learned something. I didn’t realize any Ranger ever had a six speed transmission.
Good luck with it all!
Maybe in my ignorance I refer to reverse as its own gear? I figured, 5 forward, one reverse. And trust me, there will be pictures! I'll do a couple shots of the Before situation today just for you, @Rick W ! Hmm... Might have to set up my camera and do a quick and dirty uncut video, too.
Parts list inbound!
Sounds like what I consider a “full overhaul” on a vehicle, lol.
It will be pretty darn close to a “new” truck by the time you work through that list. The good news is that it should be relatively trouble-free for 5-10 years after all that work.
Parts list inbound!
You only count forward gears when referring to a transmission or you can list it as a 5-speed, one reverse. Smaller vehicles don’t typically have more than one reverse gear though, that’s more of a big truck thing.
I listed it as a 5-speed manual. I suppose I could've said 'every gear" to avoid confusion.
What do you mean it "shears" in all gears? at 160k that thing shouldn't be all that bad, my '90 is fairly sloppy even after two overhauls but I actually prefer how it shifts compared to my '97 that's still pretty notchy and crisp somehow at 245k... it's making noises though, I'll try a fluid change sometime in the next month hopefully...
If the transmission is in neutral, no noise is made. If you put it into any gear you get a similar noise to worn out pads dragging on old rotors. The pitch and intensity is unique to each gear, and when I replaced the transmission fluid to check for issues, the magnetic drain plug came out looking like a cactus. Several large shavings surrounded in a bright red coat of some very thick transmission fluid verified my concern that the transmission is prematurely worn.
I chose the word "shear" because it is not grinding in the sense that there's no coarseness or hesitation; no need to apply more power to enable movement.
MASTER PARTS LIST
*This post will be edited to include all parts, any time a part is purchased. Items in italics have been purchased. Items in bold have been installed. Future references to parts will link back to this post to alleviate the need for searching as the post count increases. If character max is met, multiple links will be provided.
Mechanical
🛻 Drivetrain
🛻 Cooling System
🛻 Steering
  • Edelmann 2063 – Rack & Pinion – $436.79
  •  Edelmann 80863 – P/S Return Hose – $12.36
  •  Edelmann 80346 – P/S Pressure Hose – $27.79
  •  Lares 298 – P/S Filter – $15.41
  •  AAE 7289NKTA – P/S Pump w/ Pulley – $169.99
  • National A-2 – Tapered Bearing (Qty 2) – $31.98
  • National A-5 – Tapered Bearing (Qty 2) – $35.98
  • Driveworks S-9150S (Qty 2) – $19.98
🛻 Suspension
🛻 Braking
Electronics
🛻 Car Audio
  • Brand Unknown - Panel-mount USB 3.1 adapter TYPE-C female to female USB passthrough - $5.08
🛻 GMRS Radio
Electrical
🛻 Interior
  • Brand Unknown - Green option 4 in 1 Panel PD QC3.0 USB Car Charger, LED Voltmeter, 12v Socket Power Outlet w/ Toggle Switch - $21.51
  • Brand Unknown - 12V to 5V 3A Type C Buck Converter - $3.65
  • Brand Unknown - 2-ct 17CM COB White LED Strip Lights - $1.59
  • Brand Unknown - 6mm Red LED waterproof metal indicator light (Qty 2) - $1.98
  • Brand Unknown - 25/48SMD Car Interior Dome Festoon LED with T10 BA9s C5W Socket white - $2.30
🛻 Exterior
  • Brand Unknown -
    10-ct 17CM COB White LED Strip Lights - $4.62
  • Yokohama Geolandar G501 in 235/70R15 (Qty 4) installed - $1062.43
Body & Frame
Tools & Materials
TBD
*Terrible alignment $90
*Not refunded $145 for lost RA return.
Current total including taxes and shipping – $3,442.18
Oof, yeah sounds like a bad bearing on the output shaft, probably the one that went out on mine, at least if it gets better in 4th...I'd probably just look for an extra transmission, sometimes you can find them for the price of a rebuild kit...
MASTER PARTS LIST
Mechanical
🛻 Drivetrain
🛻 Cooling System
Gates XXXXX – Upper Radiator Hose – $XX.XX
Gates XXXXX – Lower Radiator Hose – $XX.XX
🛻 Steering
🛻 Suspension
Husky 431503HD – Leaf Spring – $137.99
Various MFR 431503HD – Leaf Spring – $199.79
Moog CK80054 – Control Arm – $59.79
Moog CK80052 – Control Arm – $60.79
Moog ES3461 – Tie Rod End (Qty 2) – $32.00
Moog K160066 – Coil Spring Seat (Qty 2) – $10.46
Moog 80662 – Coil Spring – $140.79
Moog K700542 – Sway Bar Link (Qty 2) – $15.38
Moog K80080 – Sway Bar Bushing – $9.36
Moog K100348 – Camber Kit – $29.79
Rancho RS55222 – Front Shock (Qty 2) – $101.58
Rancho RS55125 – Rear Shock (Qty 2) – $95.58
🛻 Braking
Electronics
🛻 Car Audio
🛻 GMRS Radio
Electrical
🛻 Interior
🛻 Exterior
Body & Frame
Current total including taxes and shipping – $2,132.58
I’m not sure I want to know what I’ve spent on my trucks. My first build on my Choptop I was all in at about $1,500 including the truck and sitting on 33” tires. When I upgraded everything and went to 35” tires I stopped counting after I hit the $3k mark. That was 20 years ago, lol. I paid $1,200 for a solid cab and bare frame to rebuild my F-150 with a couple years ago. Stuff ain’t cheap anymore. I’d still rather keep my old rigs and keep rebuilding them than buy new.
That's a really good idea, actually. I was quoted no more than $3K on a rebuild, with a 3-yr, 30,000-mi warranty. I trust the shop not to say, "oh, well the whole thing is toast, so we're gonna charge max amount". I've been a customer of theirs before and was very impressed. I only say that because of space constraints at my apartment. I do have a storage unit, but if I got a spare I'd probably still have it built and filled before crating it, so that in the case I needed to swap it out in the future I could, knowing it was one less "maybe". I'll probably do just that. Thanks for the suggestion!
It makes my eyes water just knowing that the cost of everything is so high that I'm making a bit of the money I promised myself I'd make when I got to this age, but instead of buying a house I'll be lucky to rent something that isn't bolted to my neighbor.
Lots of reasons for rebuilding over new purchases, but my favorite is that it's  mine. Nobody's trying to shut my car off, or charge me a monthly subscription for heated seats, or use my vehicle's radio to build telemetry and user data for data brokers purchased from GM, Toyota, even the DMV in some states...
No thank you. I'll rebuild until I can't anymore, then buy myself a neon green rain suit and a Chinese motor scooter.
Event Coverage
Featured Ranger Based Vehicle
