Ultra cheap offroad race Explorer turned rock crawler
Here are a lot more of the same familiar images but with the addition of almost a full 10lb spool of welding wire.
My buddy came over again on Saturday and we got the passenger side shock hoop tacked in. I had cut out some lower tabs so we tacked those in as well and were able to put both shocks in (minus springs) and cycle the suspension fully with the shocks in place. Aside from some minor weirdness with tab angles and hoop locations, everything seems to be very happy. I have just a hair of clearance with the battery box and brake master cylinder. Will for sure need to run a cone air filter.
I spent most of Sunday welding. I am probably 80% done and I don't need to build anything else except some flat pieces to box the frame around the lower mounts, tube caps, and a cross over tube that will go over the engine and stiffen the shock hoops. Hoping to have all of that done by the end of next weekend.
After that I need to remove the axle, finish welding a couple spots that I can't get to, wire wheel off all the dingle berries, and then start reinforcing the engine crossmember that is a lot smaller than it used to be. After that I can put the axle back in and work on front brakes.
So the big question is... do I paint everything? Or just wire wheel it all and let it rust? Decisions decisions...
Rick's thin rustoleum would work great here. Load it into a spray bottle and go.
I have an HVLP sprayer, might go that route. I do have about half a gallon of black rustoleum. My recipe is about 25% acetone and a splash of Japan dryer- can add hardener too if desired.
I’m just kind of over painting things at the moment. Rust makes itself and is easy…
Air filter deal is figured out I think. AutoZone & O'Reilly were useless for having the right fittings. Menard's sewer pipe section came through for me - 60 degree elbow and a rubber boot gave me the angle I needed to clear the fuse box.
Looks good. Just be aware that heat, UV and PVC don't play nice together in the long term. That's an easy enough spot to change it every couple years though. And you know the part is available anywhere.
95% of the welding is done now and we got the engine cross over hoop built this weekend. I need to built a couple gussets for the tabs on that and a couple other very small things.
No notcher for the tube? Angle would be a bit of a pain, but then you could plate the outside if you wanted added strength
I wanted it removeable for when I pull the engine - or even for replacing an injector or something like that, no room to get the intake off.
I added some gussets on the tabs last night and also capped the kicker tubes, added gussets to the frame off the shock hoops, and filled in the middle of the track bar mount. Couple little things left to weld and a lot on the frame itself once the axle is out but we're getting there.
Kinda screwed up, I unbolted one side of the cross over tube just to see how easy it comes out and then forgot to bolt it back when I welded in the shock hoop gussets. Everything moved about 1/4" overall and now it's really hard to get both bolts threaded in. I had to hog out the hole in the tube a lot. Should have had that bolted in tight to brace everything... kinda mad at myself about that. I might cut the tab off the driver's side and redo it or it's gonna bug me.
This welding wire I am using sucks by the way. Usually I use some cheap .030 US Forge wire from Menards but I got this roll of ESAB wire really cheap on clearance at Northern Tool. It spatters almost as bad as flux core, doesn't feed very well and is just dirty as hell.
