87 Intermediate Steering Shaft too short???
TABrinn
Corpus Christi
TX - USA
Vehicle
Drive
2.9L
Stock.
Maybe 3/4 eventually
Last month I bought an 87 Ranger STX Super Cab 2wd that is pretty much a Basket-Case of half-way done repairs, a rats nest of wiring and vacuum hoses, and missing hardware.
It looks like the PO started to replace the rag joint but the DD-shaft from the Steering column is about 2" too short. I tried soaking everything in PB Blaster, and forcing the DD shaft to extend from the collapsible portion of the column, then tried to extend the intermediate shaft too. Nothing budged! Maybe PO got a new Intermediate shaft from Junk Yard with wrong dimensions??? Is there supposed to be a rag joint at the top and bottom of the intermediate shaft? Isn't one end supposed to be a Universal joint? I really don't see a purpose of 2 rag-joints.
If anyone can share a good pic or drawing of the Intermediate shaft assy. for a 1st gen 2wd Ranger that would be great! I'll see if I can finish removing it tonight and post some pics.
83-88 had two rag joints
89-?? had one rag joint and one u joint.
I have a bodylift in my truck I modified the steering adaptor (soldi bar) to fit a second gen intermediate shaft and ditch one of the u-joints.
Went from this:
To this:
Watch the clocking of the ends because there is some variance but there are Jeep Cherokee XJ intermediate shafts that can be shortened to work and have no rag joints. I snagged one and the orientation wasn't right so pay attention if you go this route. The shaft will also be way long and will need modified.
Went from this:
To this:
Thanks, 85_Ranger4x4, set my mind at ease, somewhat! The DD Upper-Shaft is still about 1.5-2.5" too short. And the clocking appears 90-degrees off. In the Top Pic of the shaft installed, is the open end of the coupler aligned with the rounded part of the shaft or the flat part? There is a small hex-head set screw 9in the shaft too, presumably just as a safety measure to keep the coupler from sliding off in case the bolt comes loose.
Yeah, the intermediate shaft pinches the flats on the steering shaft.
Did the previous owner install a body lift?
There are several variations over the years concerning rag joints, u-joints, and other intermediate shaft details. It isn't too difficult to build your own intermediate shaft using Borgeson u-joints or mixing and matching various junk yard shafts. Some details in our tech library and peoples build threads.
No Lift-Kit. Just lots of half-A$$ repairs that the PO did... or left unfinished. It appears the truck may have been in a minor fornt end collision, since the front lower corner of the LH fender is slightly curled under, new grill, crystal headlights, rad, etc. But the core support looks original and undamaged. I don't see any frame damage that I can tell by eye, but there might have been enough of an impace to collapse the column.
To get the column re-extended, I would need to pull the upper DD-shaft further down? How hard should it be do re-extend? I did soak it down with PB Blaster best I could angle the can in the tight confines.
I finally got the intermediate shaft out and made room to get my vice grips around the upper dd-shaft and hammered it enough to get the few additional inches I needed. Now I need to find out what I did with the dang nut from the pinch bolt... If it ain't one thing, its another!
