Aces Killshot Fusion EFI Swap
I originally started with an RTR distributor from Blueprint and converted it to bypass the internal ignition module. You can order connectors for mag pickups that plus into the Aces VR plug. I'm pretty sure it's just an MSD part.
Here is how mine is wired:
Is there a dufferent distributor you could use? Like the one in my 3.0l, except with 8 contacts
Does the 3.0 have a distributor or is it coil packs?
I guess one could use a cam trigger and coil packs with the right signal going into the ECU. That may be too advanced for what Aces offers at the moment.
Mine has a distributor to a single coil controlled by an ignition module. That was the early progression away from distributors with points and mechanical advance stuff. Then the cam synchronizer and multiple coil packs came after that.
I bet my 88 F150 had exactly what he needs.
This is different. The distributor is basically a a cam position sensor with a distributor.
The TFI dizzy still does advance stuff I think, the computer just makes things move instead of weights and a vacuum can.
My new EFI Fudges the signal going to the coil to adjust the timing.
