lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- 5.0L
- Total Drop
- 4”
It *can* happen, but usually it leaks around the bulkhead fitting or along the tank seams where coolant just leaks outsideIF I'm following you, this extra "reservoir" (which should just be filled w/ dead-air on a 5-spd) suffered a cross-over LEAK from the main coolant-filled part of the radiator, and if your truck had been equipped with auto trans, said trans would now be contaminated with anti-freeze and water, "milkshaked" in with the ATFluid???![]()
