1984 ranger roll-along
I want to update this thread,
Time has gone by and the truck is still in progress. Angie and I separated a couple years back and the truck is still at her place.
That said. The engine is in, and is ready to by fired up and broke in. (have pics to post eventually. The passenger floor board was shot, have a new pan welded into place. hope to fire up the truck very soon. need to redo the cab by placing in floor carpets and the seats. hoping that by end july the rig will be on the road. will post pics soon. :)
here is engine sitting in the bay and ready for the final tweaks before she is fired up. cheers
  • 1984 ranger roll-along
Break ups are never easy. Hope it was amicable, which it looks like if its at her place and youre working on it.
Ive actually been thinking about this rig lately.. thanks for the update.
Sorry to hear about the breakup as well..
An admin can change your user name if you want.
slowly chewing at this project. the drivers floor is all new. and the seat is back, new carpet and all cleaned. slowly coming along. The transmission was at the shop for new seals and a bench check over. all in and now just working on getting the engine fired up. going to try using the TFI dist with a locked out advance and no computer with this rig. see how that goes. very close to firing it now. :) cheers
ok, new update. the engine is firing up, took a while to figure out the TFI Dist. set up. I was confused thinking I needed to also wire in a ignition box, so this set me back a couple weeks till I was able to figure out (by asking franklin2, Thanks) that the ignition box was not needed as the electrical box on the distributor was all that was needed. :) ....
I used the original carb that was on the truck from all the (computer crap) Angie is a whizz at rebuilding carbs and cleaning them up. so what we did was strip the carb down to only needed stuff.... I added a manual choke (redneck rigged) and then added some spacer to the idle settings ... I will post pics of this (hay wire set up) looks funny but will work great for this little truck.
the hardest thing so far has been trying to get the truck to find the right spot for the timing.... at first she was way off and the distributor was out by 1 tooth. then when we got it to fire and run, she was so far advanced in timing it was boiling over. now all we need to do is drop the timing down to retard to no fire and work our way back to the sweet spot. will post pics if anyone is interested in some (shade tree) ingenuity.
cheers
(PS) i have a floor of old collected motors over the last few years. what a savour it has been to have 3 more spare 2.8 engines to swap stuff on and off from. glad to have had these spare parts :)
I like to see pics!...
this is how we rigged up the carb, manual choke, and the idle setting is made up from crap i had laying around the tool room.... i guess this is why I never throw stuff out. found all the bits and bobs needed to secure the choke cable and make up a strange adaptor for the idle. cheers.
Positive up date!!! we took the truck out on a maiden run yesterday. she ran fairly smooth. good power, steady feel on the road. sorted out a couple vacuum leaks, and away we went. drove it about 20 miles or so, for a nice run. stopped at a gas station and didn't take long to get a couple people very interested in the rig. I can see this truck being another vehicle of topic starters. will make a small vid in a day or two of it running.
cheers :)
been driving this around on short trips as there is a charging issue, besides that, she is a decent little machine to drive. front wanders a bit so will need to jack the front up and check all the end plays, but besides that I am pretty happy with this truck. it does turn heads and is a conversation starter for sure. cheers
One thing we have found is tire inflation pressure can cause these truck to wander a bit. So, check to see if the tires are over inflated for the load, or lack there of, that the truck is carrying. So, it might not even be a suspension or alignment issue.
Even if the tires are plus sized, the pressure listed on the door jam is still pretty close to what it should be.
For example, I moved up from 235/75R15 tires to 31X10.5R15. I figured out what the stock tires should be supporting with the door jam pressure and then did the math for the 31" tires. I came up with 36 psi and the door jam said 35 psi for the stock tires.
Not a big enough difference to worry about, especially when you throw in the accuracy, or lack there of, of the pressure guage used to check the tire pressure.
The tire pressure guage I use is certified to be accurate +/- 1 psi and the 2019 says it reads about that much high.
Some people, including tire shops, will pump the tires up to the max psi on the sidewall of the tire, regardles of what the door jam sticker says. So, we do get a question or remark from time to time after that about the truck wandering all of a sudden.
And driving ford ttb or tib is like herding cats...
This. The first time I drove 96 after I got it legal... I was absolutely mortified at how horrible it rode lol. I figured.. well.. must have some wobbed out bushings or a loose bit of something somewhere... I MUST.. because NOTHING can wallow and wander around this much on a flat stretch of road..
Nope 🤷🏻‍♀️ front end is nice and tight. Just rides like ass 😅
I've wondered about paying extra at alignment time for MAXIMUM caster to try and tighten things up some. I'd use a smaller steering wheel if it didn't seriously impact my ability to see the gauges. Kinda wonder what a dual stabilizer kit feel like. I've already restricted my power steering with a bolt in the fitting for the pressure switch on the 4 cylinder.
