Aces Killshot Fusion EFI Swap
Featured Build Threads
i have turned around more than once
Just an idea though....and im not sure if they even did...but how high of elevations were the factory 2150 high altitudes rated for? Just get a 2 to 4 adaptor and bolt that on up high. Be alot cheaper and less headache....just an idea. But like i said i dont know what they were jetted at
Actually the Ford variable venturi carbs are supposed to be awesome at altitude... but then you have a pile of obsolete that everybody that has been around them seems to hate and nobody really knows if they ever worked correctly when new.
I was thinking more like cobbling togther as in being roadside\trailside and either getting it going or walking.
I once used a bottle cap to jam open a choke linkage..cant do that if a coolant sensor fails...
that kinda stuff
No need when every O'Reilly has a wall full of Edelbrock parts...
Really I don't think my Edelbrock has really ever given me any problems. I was chasing my tail last year with a hard start issue, I found a couple possible wiring issues but nothing really fixed until I put a new battery in it. It seems the voltage to the ignition was getting sapped by the starter so it had weak spark when cranking.
Really, I run a ton of carbs. Keep good fuel in them and don't let them sit forever and they run great. Again the reasons I am going to EFI have nothing to do with reliability in a strand me on the side of the highway kind of way.
Even i hate the VV carbs. Ive dealt with one or two and it honestly was one of the dumbest things ever. They never ran right it seemed.
I wasnt trying to be a dick just was throwing out an option you may not of thought of. Honestly for aftermarket carbs i love edelbrocks. Set em and forget em. Ive had quite a few and none ever gave me an issue. Ive had a couple holleys and never had much luck with them.
Athough my favorite OEM carb is the 2100\2150. They arent sexy or good for lots of power but they just work. Plus they are dirt simple.
Id be more worried about oil starvation then fuel starvation lol
Ford motors don’t need oil. Take the 2.9l for example… it rejects all the oil and coolant you pour in it and dumps it on the ground.
Ford motors don’t need oil. Take the 2.9l for example… it rejects all the oil and coolant you pour in it by mixing it together and then dumping it on the ground.
FIFY
Yeah yeah yeah
You dont know excitement untill you wonder if the smoke coming in the vents is manifold burn off or a fire.
Yeah yeah yeah
My 2.8 :icon_rofl:
Towards the end it would push the dipstick out and blow oil on the manifold out the dipstick tube.
Sounds like the Camry I had for a couple of years. The oil pressure light started flickering on for a couple seconds at a time, but with weeks in between. The car was a turd and I never put real time into investigating the mystery of whether there was a real problem or an electrical gremlin. Until the day I discovered suddenly that it was a very real problem, and the next day it went to the junkyard.
In my case it was excessive blowby... caused by the carburetor of all things.
Previous owner had hardwired it to run so the feedback carb just ran full rich and the timing didn't adjust. I durasparked it which helped it run a lot better but was going hard down the rat hole of V8 swapping by then and lacked the ambition to replace the carburetor on an already mortally wounded engine. I had the 302 that is currently in it when it started doing dipstick thing so the timing worked out ok in the end. It crossed the finish line and drove itself into the operating room. It actually still ran pretty good.
My 2.8 :icon_rofl:
My B2 isnt bad but my ranger....after it sat for a while i drove it to the gas station and the attendent lady said "excuse me sir but i think your trucks on fire"....
The look on her face when i shrugged my shoulders was priceless. I could literally smell the oil inside the station
Does my plain rubber hose and screw clamps detract from my build?
Yeah, you can't see a thing under that big block air filter housing...
Because I am kind of weird.
Most carb guys don't stray far from home. Even fewer still offroad with them.
But also... not many aftermarket EFI guys go farther from home either. PCM dies and your truck is bricked right there until you get a new one mailed to you unless you pack a spare or can backwards swap to a carb on the fly. Most use GM based injectors and sensors so they are available everywhere.
And also... dare I say even fewer are running 40yo rigs very far from home with any fuel delivery system.
Yet here I am hammering down 10-15hrs from home to offroad and camp. :icon_twisted:
My faithful Edelbrock has done very well in the 14 years it has been on my truck. However if you have been following the Vagabonds... they were up to almost 13k feet this year. I went thru all the charts and everything, I can only get my carb dialed to 7k feet. I was going to try it anyway because science... but with a new baby this summer things just didn't work out.
I looked at getting a carb cheater, they said it would help compensate for altitude... and then raised the price to within $150 of aftermarket fuel injection. The only real advantages is at the end of the day if the electronics crap out I still have a carb and I don't have to touch the fuel sytem.
But I want to redo the fuel system and add a return style regulator anyway to maybe make life easier on fuel pumps and help cool fuel (which would also help fight vaporlock at high altitude as well)
So I set my sights on this:
So to answer your question... if I was to use the truck as a normal person would use a 40yo truck the carb works great. Even for long distance trips it has worked great so far. But high altitude isn't going to play fair with it.
Ah yeah I suppose that air cleaner does do a good job of hiding your sub par hosery 😉 I'm totally kidding lol.. I still think the warthog deserves the top shelf treatment though!
Anyone know what size the quick disconnects on the fuel pump are called? Pump assembly is for a '86 Ranger.
Event Coverage
Featured Ranger Based Vehicle
