2000 V6 3.0 Automatic reverse lights
Ryoshin
Forum Member
Jacksonville
FL - USA
Vehicle
Drive
I have a 2000 V6 3.0 and the reverse lights do not work. I replaced the bulbs just for sh*ts and giggles but that didn't fix it. I've been doing a lot of research online and there seems to be some sort of back up light switch that's on the transmission but everything I'm reading and every part I find says it's manual transmission only, so I'm not sure if that could be the issue. I have checked the fuses and they are fine as well. I'm just kind of lost on how to fix this and was wondering if anyone could help. Thanks in advance.
It's built into the Neutral Safety Switch, you need to replace the whole switch.
Okay thank you for the information. Would this also make the shifter selector work better? Because mine is kind of janky. I just watched a video on how to replace it and although it looks pretty simple there are a few nuances that look like it could be irritating.
Pretty sure those are the same thing...
Yeah. Thanks for the help and actually linking the correct part even though I was able to locate it already. Do you have any idea what size the nut is to remove it? The videos I've watched it looks pretty big and I'm not sure I have a socket that big and they're not saying what size socket they used.
Not a clue. I haven't had one off since about 2010. I think I used an adjustable wrench then.
note the circuit goes thru 124 & 135 twice, going to & from the switch.
C124 and C135
those are connectors
298 and 140 are circuit numbers, so is 57.
VT/OG is a violet colored wire with an orange stripe.
G200 is a grounding screw.
S126 is a splice, check that too.
EDIT: or do you mean you can't the connectors in the truck?
they're in the harness that goes over the bell housing then near the top of the tranny.
C124 and C135
Admittedly I have not even looked under the truck or for any of the connectors or harnesses yet. I was just looking at the diagrams and I'm just bad with that kind of stuff when it comes to electrical. Hopefully I can get around to it soon, put the truck up on some ramps and get under there and look around. I'll do my best and see if I can locate everything and see if I can find anything that looks wrong/off.
I'm in the process of fixing multiple little issues on this truck at the moment. The truck had a bad ground which I didn't find out until after I bought it. Sometimes it would start and sometimes it wouldn't. I replaced the starter and thought that was it but it quit starting again. The factory ground is bad somehow, I'm not sure why. I ended up running a very thick gauge audio amp power wire from the negative battery terminal and bolted it to the engine block, haven't had a problem since. Before I had to connect one jumper cable to the negative and the other end to the engine block to get it to start. It seemed to have fixed a lot of the weird issues the truck sometimes showed. Sounded like some of the speakers were blown and the truck would kind of almost act like it was misfiring for a few seconds, turns out it was all bad ground. I know this isn't necessarily related to my reverse lights, just noting that this truck definitely has/had some electrical issues so maybe related to reverse lights not working.
