TRS Event 2025 TRS Fall Colors Campout
Featured Build Threads
Cool. I guess I need to mail a check soon. Last fall, he just told me to pay when I got there. But I feel more secure knowing I've paid ahead.
I may be able to make it, but unless something dramatic changes, I'll probably be selling the Ranger prior to October. It's barely been touched in the last two years.
Would be glad to have you there.
Just touch it.
Just touch it.
If I add transmission fluid, I can move it. Then it will start marking a new spot on the street as it slowly drains back out for the next few months.
Honestly I might just bring a motorcycle and hitch a ride in someone's else's truck if there are open seats.
I'll have one open seat if the girlfriend's daughter tags along like she said she wants to.
Just show up and have fun.
Wife is coming and rented a hard-sided camper for me to tow. The dog is not coming.
This means I will order a Curt Echo brake controller and get the tranny fluid and filter changed. I’ll probably need new tires by then. Trip is getting expensive. :D
To be honest, I’m not at all impressed with the Curt brake controllers. I’ve had two in the F-150 and both were junk in short order. Dad had Tekonsha in both of the dump trucks and I’m thinking that’s going to be what I buy next. The only problem he had with them was the ground failing because the shop was dumb about how they connected the grounds (this was before I really got into vehicle wiring).
I use Tekonsha and like it. It was one of their high end models when I bought it.the research I did at the time indicated that was the go-to brand.
We always write the Tekonsha brake controllers into our bid specs. They take a beating from the abusive county drivers.
The Echo simply connects between the factory 7-pin plug and the trailer plug and is controlled by your cell phone via Bluetooth. Be okay for the one time I may tow a trailer with brakes. If we end up buying one then I'll get one that's hard-wired.
If you have a factory 7 pin on the back, it should be already wired from the factory, you just need the correct adapter harness to plug it in. I think our fearless leader did one in TRS 3… not sure what brand he used though.
Page 6 has all the goodies
Event Coverage
Featured Ranger Based Vehicle
