lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
I don’t have my 97 Explorer here and don’t have time to go look at it (it’s about 45 minutes away in the opposite direction that I need to travel today), but it should be VSS in the rear axle.I’ll check the wiring diagrams for the 97 Explorer to see what those say, and then verify once I get into it. Fingers crossed it becomes a non-issue but my hopes aren’t high on that one. To your point, crossover years suck.
As for axles, I will not be doing any off roading at all. Im going for a RCLB sleeper via the following plan:
Whatever power that all adds up to is what I will have and be more than happy with. Not sure if absolutely required but I’m betting an 8.8 from the Explorer is a smart move, or at least a 28 spline 8.8 from another Ranger. Seems silly to not just use the beefy 8.8 I already have on the donor car though.
- swap in the 302
- add TM headers
- Swap in XE-264-HR cam
- Port and polish the heads and rebuild with upgraded valve springs, rods, etc.
- Cold air intake
- Custom exhaust
- Convert to 5 speed with custom T5
I used the Ranger GEM in both of the builds I’ve done so far (I built one for my dad a number of years ago).
I did use a diff cover with a main cap brace on my Green Ranger build. Tubes haven’t been welded yet and I didn’t do any sort of truss yet.
TM headers are worth it.
Mustang rear brakes may be better than the tiny Explorer ones.
Not sure how much a port and polish will get you. I tried to do a little gasket match porting but it really wasn’t necessary, I just did very minor clean-up. My 4.0 actually took some work.
Stock intake is a cold air intake, it draws from behind the passenger headlight.
I had a local exhaust shop do stainless 2.5” duals. Aftermarket high flow cats, Magnaflow crossover muffler (crossover mufflers eliminate the need for an X or H pipe on duals). Dad’s build we used the Explorer cats and custom exhaust after that with a Magnaflow crossover muffler.
I believe the M5OD from an F-150 with the 4.2 is the recommended manual transmission because it puts the shifter in the correct spot. I did automatic with both of my builds. My green Ranger is getting a shift kit (stage 2) plus some other mods. Curious to see where that puts me.
