I bought Kevlar socks for my wires. They work good.
It's been taking 20psi for a couple weeks now. Again, back at being out of injector. I don't know why it hasn't blown up yet. Everyone says it shouldn't be taking this abuse.
see.....FAFO timeline.
dont worry. you are merely scaling data points to add to the FAFO scale.
what was the ring gap? over 30?
If you had more traction, you’d have more load, which might result in![]()
it's whatever it is at 200k miles, lol. didn't do anything to the short block... well, i needle scaled off the rust and painted it.
.0065 per inch of bore rule of thumb on boost when you push it. 200 k is pretty well worn and likely why its working good. at those levels with so much use it really is impressive. if you put new rings in or get a fresher short block take the time to gap them. just pull it apart ... gap... reassemble. going past 10 psi regular its a good idea
