pats sux on its best day. turning it off is a good idea. not having it in the scenario at all is a better idea.
the explorer v8 should be using the vss from the diff iirc. there is confusion due to the 4 liters having both sensors and some gems certainly do not like each other. these crossover years suck. i know some of these trucks have very specific gems, and if these problems arise just swap in a different older dash or go aftermarket...
or as mentioned keep the explorer system complete if you want it all factory.
as to just the axles...
the 10 and 11 axles can be disk as well..the traction control/acs mandated stuff doesnt work as well with drums...and the mustang kits from summit work well too.
Free Shipping - Ford Performance Parts Mustang GT Rear Brake Bracket Kits with qualifying orders of $109. Shop Disc Brake Kits at Summit Racing.
www.summitracing.com
or just robbing and swapping vic/sploder stuff.
as mentioned the stock explorer power on the street can work ok with a 7.5 anyway
but if you build it...past 300 whp...
actual power is for sure a thing....street or track...verse off road...all factors.
the reason to run the explorer is the 31 spline axles and beefy axle tubes. using a load bolt cover and proper trussing and welding they are practically indestructible sub 1100hp drag racing or for street duty....
off road is a totally different story....especially for the 7.5.
i can easily destroy a 7.5 with big tires off road in minutes with a mere 3-330 hp. the case deflection and one wheel fire at wot spits spiders right through the plastic diff cover in short order....even faster with a junk ass traclok.
case deflection isnt as bad with the 8.8....but spinning the tubes with the 8.8 is a given without welding and trussing.
again the explorer v8 should be using the vss from the diff iirc. i may be wrong, but that data is here on the forum... and the confusion due to the 4 liters having both sensors and post 93/4 some gems certainly do not like each other or at least playing in another vehicle even know they seem optioned the same..
