- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Total Drop
- few inches
- Tire Size
- ~30"
getting offset torsion keys will soften the ride.
Would it though? The torsion bar still needs the same amount of preload for a given ride height, the offset keys (which it appears he has) just allows for more preload before the adjuster bolt reaches it's limit. Same deal for drop keys when lowering one, same ammount of preload for given height, but the drop keys allows for more drop when stock key would bottom out on the adjuster bar.
@JJMaine
I'm still a bit lost on exactly what's done to your truck and how much lift it actually has. 2" or 4"? If it's 4 inch just through a torsion adjustment, thats going to be your problem, way too much preload on the bars. In that case I'd be looking to install a proper lift kit like Bobby was talking about and remove all of that torsion bar twist.
I agree with the guys talking about that rear shackle. You (or who ever installed them) have got the bolt turned around backwards, the bolt head should be towards the frame of the truck. That bolt is likely limiting or preventing shackle movement causing a worse ride.
As long as the suspension isn't so tight that it prevents movement, a good set of shocks will go a long way towards improving ride quality. Once other suspension issues are sorted, look into something good like a set of Bilsteins (have used) or Rancho (haven't used).
If you are not encountering issues with binding in the suspension and your torsion bars are just too stiff at that preload, maybe a softer set of bars. There may be an article in the tech library that discusses which codes are harder and softer. Also a coil over conversion would get rid of the torsion bars all together which is a large source of complaint about these trucks. You;d get a better ride and more flexable suspension at the same time.
