- Jun 26, 2022
- Age
- 54
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 3.0 V6
- Automatic
- Total Lift
- 3"
- Tire Size
- 255 75r16
- My credo
- If you cant fix it blow it up
I have a 99 Ranger xl 3.0 Vulcan flex fuel 4wd torsion bar suspension, 4r44e transmission 112" wheel base 7.5 3.73 rear abs rear only and my speed/ abs sensor is in the rear. I upgraded my leaf springs from the 2&1 to a 4&1. Opening up my rear and seeing groves in the carrier from the pinion made me realize I'm buying some time with the bearing replacement. With the price of replacing the carrier and everything, then doing the work its cheaper to just buy an axle and swap it out. This was my 1st experience and lets say 3 times was a charm with shimming the carrier. Now should i go with an 8.8? I do roofing, and remodeling with it so it gets some weight at times. Is there an axle that has the sensor in the rear? What year axle can i just throw under the truck and jook up that dont have to be modified (if any)
