Terry
What about the reservoir?
They should fit. They should all fit the standard tube with a ridge-style quick connect.I have been hunting fuel lines. I know what I am going to do but I have the older style connectors the have the little clip that holds the line on. All the other lines I am seeing a the push on type. Will they work on my truck?
Sorry no posts. Got hurt at work and could not do anything. My truck has 2 pumps. I bought 2 pumps with all the parts, flow and pressure for a later model truck. It even came with both style filters for 77 dollars. I pulled the bed. Then I pulled the rear tank pump not knowing what I needed to do to fit the new pump. The old low pressure pump is shorter than the new pump. The fuel output is also smaller than the old pump. The provided hose would not fit the metal line. After a trip to the autoparts store for bigger hose, I was ready to go. I had to cut 3/4 off of the metal line. After that and a little bigger hose it went onto the old frame. I did the same thing with the front pump. I tested both of them. Started up and the gage worked. Of course it overflowed the reservoir but it worked. Now I need to remove the reservoir, frame rail pump and redo the lines. I am attaching some pics for reference.I saw some people talking about changing the in tank fuel pumps on my 1987 ranger from low pressure to the high pressure pumps in the newer rangers. I have dual tanks and I am looking for what year pump I need to buy.
Well, I removed the frame rail pump, the reservoir and for not the brack covering the reservoir. I think the low pressure return line should be OK. The line from the selector valve to the filter line is leaking to put it mildly. I bought the 12 inch metal lines for both lines, the replacement lines with fittings and the funky push connectors. DONT EVER USE THE PUSH FITTINGS. I am going to call NAPA tomorrow and see if can build me a fuel line. I got barb connections but that's the last resort. I'm posting a picture of the removed part and leaking fuel lins and fitting.Sorry no posts. Got hurt at work and could not do anything. My truck has 2 pumps. I bought 2 pumps with all the parts, flow and pressure for a later model truck. It even came with both style filters for 77 dollars. I pulled the bed. Then I pulled the rear tank pump not knowing what I needed to do to fit the new pump. The old low pressure pump is shorter than the new pump. The fuel output is also smaller than the old pump. The provided hose would not fit the metal line. After a trip to the autoparts store for bigger hose, I was ready to go. I had to cut 3/4 off of the metal line. After that and a little bigger hose it went onto the old frame. I did the same thing with the front pump. I tested both of them. Started up and the gage worked. Of course it overflowed the reservoir but it worked. Now I need to remove the reservoir, frame rail pump and redo the lines. I am attaching some pics for reference.
