E-fan Swap Question 1993 3.0 4x4 Splash
Unrelated to this particular thread, but I'm concerned one (or more) of my "new" fuel injectors may be leaking. I already had to return one of the six I ordered as it came only partially assembled. Ha. If not for that I may have expected installation error, despite checking and rechecking my work. Pretty strong fuel smell coming from the intake manifold when I crack the throttle plate. I had some issues with starting as well after the install which I had attributed to maybe air in the fuel line. Fuel pressure is good KOEO and while running. Fuel pressure regulator also seems to be working fine. So we'll see... I'll message Rockauto tomorrow and see what they can do for me as I've already returned my original injectors as cores.
Got the Big 3 finally finished and mounted the fan today.
Its going to do a lot better job of pulling air through the radiator if you block that opening around the outside of the fan housing.
I'm gonna be curious on how well that works.
How close to the radiator is the fan?
I like that much better then running zip mounts through the radiator.
Agreed. My original intent was to find something that I could cut to fit the gap and bolt in between the mounts. Not sure what kind of material I will use. I *might* try it without it and see how the flow works as it sits now.
Same. I have high hopes as it has less pass by airflow than the stock e fan on some Rangers.
I'd say an inch or so? I wanted to flip the brackets around and recess it deeper, but it won't quite fit that way as the circular section transitions to the rectangular dimension a bit too soon. If I did more modification it might work, but I think diminishing returns at that point may make it not worth the time and effort.
Thanks! Me too. Zip ties are tried and true, but I worry about just how well those tiny fins would hold the weight of the fan over time. In my opinion, could cause early rad failure. Though that's just speculation. Haha
Case in point, here's a stock Ranger e fan on a later model truck. I did notice that it is MUCH closer to the radiator though. Possibly touching. So the extra space around it may not be as much of an issue as on mine.
I did the zip tie install through a brand new 2 row explorer radiator when I did my V8 swap years ago.
Even though I never had an issue with the install... it sure looked like an accident that was about the happen.
Keep us posted on how it works after you get stuck in stop and go traffic for a 1/2 hour.
That space around it comes more into play due to the gap you have between fan and radiator.
Nice! For ease of install it sure is tempting. Especially since I could probably bolt the stock shroud around it once it was attached to the radiator. If it doesn't work out I still have the zip ties that came with the fan. May keep them in the truck in case of emergency. Lol
Oh yeah, I live in Houston so traffic that's only 1/2 an hour is a good day. LOL
That makes sense. As since mine isn't touching the radiator it could allow the air to pass in from the engine side of the fan instead of through the rad.
Any thoughts on what type of material to use as an air dam? I saw someone use aluminum, but that seems like a headache I do not want. Lol
I think I would try to mod your brackets to set the fan deeper in the shroud... even shift it sideways to clear the shroud.
But honestly... I would see what it does as is first.
Went with the upper rad hose for my temp sender. Fit nicely under the intake tube when I test fit. There's just enough straight section in this part of the hose for the adapter and this will keep it out of the highest section. Here it is about level with the top of the radiator instead of above it as it would have been if I would have installed it further up in the hose. Hopefully that will ensure that it stays in the coolant even if it does get a bubble in the hose. Need teflon tape or I'd have the sender itself in too.
Thats nice work, Ive been taking notes. What made you go with Derale?
Thanks man.
Size worked for my fan shroud, pulled a decent amount of air and the current draw seemed to match air flow claims. I read somewhere that current draw *can* be a decent indication of actual flow rate, which makes sense imo. Also it was sold by Summit which I am partial to over Amazon as I have had issues with quality control from Amazon in the past. All in all that is more on the supplier and less on Amazon as a whole, but peace of mind and whatnot, I suppose. Lol Price was decent too comparatively. They also sold associated relays specifically for the fan. Reviews were mostly positive so that didn't hurt either. But there could very easily be better options out there that I missed or passed over.
My current dilemma is where to put these relays under the hood. I'm pretty tempted to slot them in my stock under hood relay/fuse box, replacing the fog light connection and the two free slots with the three relays I needed for this job. Working on how I might do that now.
Anyone know where that wiring diagram that included wiring your a/c into the fan actuation went? I swear I saw it some time ago, but can't seem to find it now.
This one:
is really good, but doesn't include a/c.
