INFO Photos of different wheel/tire sizes on stock and lowered 2WD's
Featured Build Threads
What are your thoughts about Black Rhino truck wheels? I want to purchase a set of two-toned rims and have seen a lot of great designs from this brand. I wonder if the price is worth it for its quality.
OK, I'll play. This is the low-buck edition. If you're looking for something radical, keep moving. :)
Drop: 2-1/2" rear w/ hanger flip, 2" front with Western Chassis coils
Wheels: '07 Mustang 16" X 7" Base Model
Tires: stock Mustang 215/65X16 BFG's - I plan on a set of 225/65X16 General Altimax HP's when the BFG's are done as the OD of these is nearly identical to the stock 225/70X15's.
Offset: 37 mm
Spacers: 1-1/4" cheapos rear, 1" Eibach front
thanks nice. I have been looking at mustang rims for my 92. Thanks for sharing.
Update. New shoes.
  • Photos of different wheel/tire sizes on stock and lowered 2WD's
what size and make are those tires and rims? 3/4 drop kit?
2020 Mustang wheels, 18”. 235/50-18
3/5 Drop..with 5/8” Poly spring isolator.
With 1.5” Wheel Spacers.
‘83 on stock suspension but it sits a little lower with the 5.0 up front and 150 lbs of steel under the bed for traction. I also added anti-rollbars to the front and rear. Still has a nice soft ride but it corners flat as can be.
255/60 15’s on 15x8’s in back with 235/60 15’s on 15x7’s up front.
I have a 98 2wd ford ranger and i have a set of track pack wheels off of my 2014 mustang the back fit fine could use some spacers to move the wheels out to fill the fenders out. But i cannot get the wheels to fit the front wont fit over the hub did you have to use the 1 1/2 spacers to get the front wheels to go on?
18" x 8" Boyd Coddington Junkyard Dogs w/4.5" backspacing & 225/40R18 Hercules "Ironman" tires.
I'm using Chassis Tech 3" drop beams on the front & Competition Engineering ladder bars on the rear. It also has Slam HE-6 bags on the front & Airlift 2600 bags on the rear. We set the suspension up to match the 3/5 drop, beam/rear flip kit I originally had on the truck at full ride height.
Dose the rears clear pretty good?
Eagle 212s, 18" front and 20" rear.... DJM kit and trimmed fender lips. Going on air next.
‘83 on stock suspension but it sits a little lower with the 5.0 up front and 150 lbs of steel under the bed for traction. I also added anti-rollbars to the front and rear. Still has a nice soft ride but it corners flat as can be.View attachment 59153View attachment 59154 255/60 15’s on 15x8’s in back with 235/60 15’s on 15x7’s up front.
I’m thinking about getting those for my ‘06.. I’m 2WD . I don’t know the offset.
Where did you get them?
David’s Rally Wheels on line.
Upcoming TRS Events
Featured Ranger Based Vehicle
