I need a radiator for my 2001 Ranger. Opinions on brand, etc?
my hhr uses some crazy thing with a snap ring that you just push in, Id rather have a threaded fitting. Many years ago on my first car (79 amc concord) I replaced a radiator and somehow forgot to hook up the transmission lines, didnt go far but luckily I didnt damage the transmission. Im still waiting on the new radiator for the escape to show up, think thurs was my estimated delivery date. Ive not even looked to see how everything hooks up on it.
Well, the radiator doesn't fit. The brackets welded to the side (that sit on the factory rubber mounts) are too far towards the rear of the truck, so I plan to have a welding shop move them for me.
I also have to adapt the trans cooler lines. Instead of cutting the factory hard lines and re-flaring them and shortening the flare nuts, I'm going to use the adapters that I removed from the original radiator. I'll turn the thread off of them on the lathe, cut 5/8" x 18tpi threads, and cut an inverted flare so they thread in to the radiator. The factory hard lines will then thread right in to them.
The problem with the lines is that the chinese can't build anything right. They made the trans fittings welded in to the radiator too shallow for the Ford flare nuts to thread deep enough. I could shorten the nuts and re-flare the lines, but I'll try my method first.
Other than all of that, the radiator looks to be of nice quality. lol
Did this radiator come with the same MINI fill neck or the larger SAEA standard?
My escape radiator came today, hopefully it wont be a job-from-hell to change out.
Dont suppose I could get dimensions and which one you got?
In my quest to add a/c a factory 5.0 cooling system or better has a certain appeal...
I won't care about trans cooler and I will have to built my own lower mounts anyway.
I possibly ordered the wrong year.. Even though most of them state 97-11 some of them look to be built differently. I'm beginning to wonder if it's me or the chinese not knowing shite from shinola.
I believe I should have bought one for a 97 model V8 Exploder. I got so focused on which features I wanted, I overlooked the year on accident. I wanted the style of petcock that's on the one I bought. That's where I went wrong. The models on Ebay for the 97 Explorer all seemed to have a different style petcock that I'm not fond of.
Here's what I ordered: https://www.ebay.com/itm/133833867795?hash=item1f291ec213:g:LAQAAOSwn5ZZcIbg
I'm still forging ahead with modifying this one instead of sending it back, well because I've already got it in my hands. It's at the shop getting the mounts cut off and moved about 5/8" towards the front of the truck. I took the factory trans line adapters out of the original radiator to work and turned the threads off, and cut a flare bevel in them. Bought a 5/8 x 18tpi die and cut new threads on them. They seems like they'll work now IF the bevel is right to seal properly.
I have to wait until Wednesday to pick up the rad from the shop though. After that, I hope it's a bolt-in. lol
I believe this is the one I should have ordered, and I would have, but I just now found it. Notice that the lower mounts on the side of the tanks seem to be welded on flush with the front of the tank.
63732
What's odd is that the one I bought, from the pictures on Ebay, the mounts also seem to be mounted flush with the front of the tank, but they're definitely not. I'm wondering if my radiator was welded up wrong.. Or, again, chinese shite from shinola.. Who knows?
Mine:
63733
63734
The radiator I installed in my 87 V8 truck fit very nicely if you can make yourself accept the price. The lower mounts were easy to make, and I cut off the factory Ranger mounting points and just re-welded them where I needed them, and used the factory round rubber isolators. For the locating pins on the bottom, I used some internally threaded hex pieces (local hardware store - lamp parts I think) that were about 3 or 4" long that fit inside the factory rubbers snugly, cut some all-thread and loctited it in place in the hex pieces, drilled a hole in the lower radiator aluminum plates, inserted the all-thread/hex pieces, and loctited them in place with a half-nut. I can probably get some pictures if you need them. It was cheap and easy to make those. Cutting off and re-locating the factory lower mounts was the hardest part since you'll wanna raise the radiator up off the bottom of the core support hole it sits inside of. I just shimmed mine up temporarily to get the factory mounts welded at the height I needed them, then removed the shims once welded in place. I think I later added some firm foam under the bottom radiator channel just for added support. It's been flawless so far. Couple years now..
Here's what I bought for the V8 truck: https://www.ebay.com/itm/154557258996?hash=item23fc549cf4:g:oxkAAMXQgJRQ-rSc
It fit up inside the core support very nicely, tucked way far forward. Left more than enough room for the stock 92 Thunderbird mechanical fan.. Even after adding an A/C condenser in front of it at a later date.. If you can't accept the cost, then there are a lot more options on Ebay now then there were back when I ordered mine.
