NEED 3 ROW RADIATOR 94 3.0 A.T.
Hey thank you everybody for your replies .I've actually tried a Heavy Duty fan as well ,same thing bad gas mileage less power. Bought the insde electric fan hooked it all up manual and thermostatic, it seemed to drag the idle down then put an extra heavy-duty 250.00 generator in there, didn't help much. It's always had kind of a rough idle issue unless the a/c is on. And if it gets hot like I'm talking about while idking for 20min. and I shut it off and come back in 5 minutes and start it It misses badly even while giving it gas. I've taken it to the best mechanics probably spent $3,000 trying to get that stupid problem fixed ! finally felt like a fool and gave up. Put in a new computer ,sensors etc. I'm an elevator mechanic and troubleshooter ,so it isn't easy for me to give up, but when my wife rolled her eyes LOL I thought that's probably enough .I actually use it as an elevator service truck ,so Ihave more weight than it probably should have although it does great with it . If I turn the AC off the temperature comes right down.
Make sure your AC condenser isn't clogged full of leaves and shit too... It is pretty common on our trucks for crap to get stuck between the radiator and condenser. If it's icing up in there or just can't pull enough air through, there will be issues.
that part will never ice up, but the part about dirt and debris between the condenser and radiator is spot on. also check the fins to make sure they are all not bent [\over
How in the name of Christmas would he have gotten ? in there? Unless..... @Dirtman ?!?!?! Did you poop on his A/C condenser?
