Ehendershot
New guy here with an issue. Last week I was on my way to work, going about 60, when all of a sudden it felt like I hit something for a brief moment before continuing on. Then the truck started making a terrible noise and I pulled over. At first I had thought I blew a headgasket or something because of the loss of power and the sound (I've had my vintage Honda twin blow a head gasket and sound/feel similar when running on one cylinder). But the truck was idling normally and revved fine. It all looked normal. I could smell something hot towards the rear of the truck but it quickly faded so I though maybe I had a rear brake seize for a second and then release. As soon as I started out, it sounded terrible again, so I limped it to a gas station to get me off the highway (with the gas station only being about 1/3 of a mile or less away. When I got to the stop light right before it, smoke was pouring from the back of the truck. At the gas station I saw the rear diff cover was completely covered in fluid and had a small drip. Had it towed home.
Fast forward to this weekend when I opened it up. I approximated that maybe 1/2 a cup of diff fluid came out. There was some silvery specks in the oil so obviously something let loose, and I found small chunks in the bottom of the case. I'm guessing at minimum I smoked the bearings, but I also need to inspect the ring gear and clutch pack more closely. Someone has been in the diff previously because the huge amounts of blue RTV that held it on made it interesting to get the cover off, plus the bolts came out with RTV on the ends.
Is it worth trying to rebuild the diff, or is it cheaper to just buy a low mileage used one? I have looked at the axle chart and I am also weighing my options on replacing it. Not sure what to go with. Local yard says they have one with 100K on it but a open diff and 9" brakes instead of 10". Would that make a huge difference? I would normally take my time on this but it's my daily and I'm borrowing a buddy's ranger until I can get this fixed. Never done diff work before so I'm completely in the dark.
Truck is a 98 B3000 cab plus with 4x4, auto trans and F7 rear diff (7.5" 4.10 with limited slip) 204K miles on the clock.
