The 98 Ranger C184 is similar to 99~01 Explorer C125. Each of these connect to a small engine harness that goes to the A/C compressor clutch, A/C high pressure switch, starter, etc. This harness is different for Ranger or 5.0 Explorer.
The Explorer connector may have 2 additional wires for sensors related to the Message Center (trip computer that was not available on the Ranger).
Also, the 99~01 5.0 Explorer oil pressure switch wire goes through this connector but the 98 Ranger's is routed through the 42-pin into the main engine harness.
The Ranger C179 is for 4WABS (if equipped), similar to Explorer C140.
I was hoping you might drop in and lend a hand. I think I may be missing the small harness for the A/C compressor clutch and the A/C high pressure switch, or at least part of that harness to include those connections. I used the 2001 5.0L Mountaineer Engine Harness and Battery/Starter Harness.
Here is a photo of a cropped pigtail that runs off the alternator portion of the harness near the AC compressor location. I am not sure what this would have included other than ac connections. This is from the salvage harness that came with the salvage 2001 Mountaineer 5.0L I purchased.
Here is a photo of the 1999 Ranger 3.0L Starter/Alternator harness I saved from disassembly. It includes one of the male 12 pin connectors discussed in your previous post. I installed the 2001 5.0L Mountaineer harness to replace the one pictured here.
Here are two better photos of the 12 pin connectors in question located on the truck.
The first runs directly off the positive side of the battery cable/harness (2001 Mountaineer 5.0L harness).
The second one runs directly off the harness that includes the 42 pin connector on the chassis side (1999 Ranger 3.0L Harness).
Thoughts?
Questions:
The Battery Harness I removed from the 3.0L Ranger had a male 12 pin connector. The Battery Harness I installed from the 5.0L Mountaineer has a female 12 pin connector. Is it possible these connectors are for the same circuit? I am wondering if the two female 12 pin connectors remaining on the truck should be “connected”. I am going to pull the EVTM’s for both and start reading but once again I would feel better with a second opinion.
Are you sure about c125? I show it as c139 in the Explorer EVTM, same as Ranger c184. However, I am new to this and I am not 100% sure of my findings.
