I'd love for you to find two diesel gas stations right off the highway about 60 miles apart or so, fill up until you can see it in the fill tube, reset the odometer (assuming it's accurate, which it should be), and record mpg to the far station, and again at the starting station. Set cruise at 70mph.
Regardless...congrats! What's left?
I've been commuting with it for a while now and have put on a couple tanks driving a 50/50 mix of city highway with max speed of 65mph. I always fill right to the brim like you describe as it really is the most accurate way to fill up. The problem with this method, my additional capacity and the fact that the diesel foams pretty badly means it takes me almost 10min to fill up the truck. I'm thinking the foam is the result of the anti-siphon screen in the bottom of the fill tube? I'm definitely going to remove this bad boy if that is the case.
Anyway, here are my first few tanks:
642.1 miles on 16.636gal = 38.6mpg
587.6 miles on 14.997gal = 39.2mpg
304.5 miles on 9.616gal = 31.7mpg
Last fillup was to calculate mileage pulling these around.
