Fuel Filter plumbing
To recap: there are three outlets of my particular fuel pressure regulator as well as a pressure gauge (listed in order from top to bottom as viewed in the next picture)
1) Outlet (to fuel filter)
2) Pressure bleed (back to tank)
3) Inlet (from tank fuel pump)
Here it is all hooked up to the filter and injection pump. Once everything was connected I set the pressure to ~4psi with the engine at idle.
A note on this regulator. If I were to do it again I would buy the Holly 12-803BP and add in the gauge separately. The fitting that Nitrous Express added had a severe leak the second I put fuel pressure to it. It took four different tries but I finally got it to stop.
