- Apr 13, 2008
- Fort Lauderdale
- State - Country
- FL - USA
- Other
- FLEX-fuel, baby!
- Drive
- 4WD
- 3.0L
- Total Lift
- 0" bone stock
- Tire Size
- P235/75R15
- My credo
- A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
My trusty Ranger rolled off the Twin Cities line 14 years ago this month!
Though only 46,000 mi. on the odo, components are AGEING anyway (sub-tropical humidity + coastal salt spray).
Recently did the rear brakes (both cylinders leaking), all went well, but noticed the steel hard lines are rusting badly--ROUGH thick rust. I've been told the rubber flex lines are likely decomposing from the inside as well, and dark color of brake fluid lends to that assumption.
ANYWAY, makes no sense to do this piecemeal (bleed/flush ONCE, eh?), so it's STEM-TO-STERN time, replace ALL lines, master-cylinder-all-4-terminations.
Just wondering the best way to go, i.e. pre-bent vs. bend and flare yourself, and SOURCES for all the flex lines.
THANKS IN ADVANCE!
THANKS IN ADVANCE!
