Actually I have the harness almost finished lastnite.....Im hoping to fire it up before the weekend.
Feeling pretty good about todays work.
Got the new seats put together and bolted in so I can start cutting floor and figure out the shifter.
Im on the look out for a tilt column now cuz its a tighter fit than I remember in these trucks and its easier than goin on a diet.
Shortened a driveshaft to fit today but pulled a rookie move and welded it up before I made sure the ears were all lined up..u-joints are out of phase now so this will just be a temp. shaft and I will have a much better one made before it see's daily driving.
Here is my junkyard fresh mint dashpad.
I also got the pinion angle set and welded up the spring perches. Then I made the mounts for the Mountianeer traction bars and welded them to the spring plates. I had to cut and sleeve them to get them at the correct length.
Next Im going to start on the interior and wiring.This will take some time to get right but Im still hoping to fire it up in the next two weeks.
Anybody else see what I'm seeing in this pic? Look at the top left corner of the pic.
I see what looks like your reflection in that pic
I knew that it was something like that, I'll be doing similar with a cut down explorer cross member. This is what I was referring to. VVV
Good, so someone else does see it. You know how people are always finding the face of Jesus in things. Not saying it's Jesus but was surprised to notice what looked like a face where there shouldn't have been one. I don't think it's a reflection, just discoloration of the metal there caused by heat from welding. Just wandering if any body else had noticed it.
On other note the truck looks to be coming along good. Congrats on the STOTM win. Personally I would have liked to see it running first, but with the amount and quality of work you've put into this you deserved it regardless. I have a feeling that you'll be winning it again sometime next year (if not TOTY this year). How do those Stang seats compare to the bench? I currently have the solid bench seat and really like the way I fit into the truck with it. I want buckets and trying to decide which to go for, most I see loose leg or head room and I don't want that.
