With the Ford Ranger’s return to the North America market and no sign of Ford offering the Raptor version here, various companies have turned to offering their own version of a Raptor inspired Ford Ranger.
One of those companies is Automotive Performance Group. Shortened to APG, these guys are glad to sell you the Prorunner Series 1 upgrade package. APG sought to engineer a conversion package that brings real off-road performance and styling to the Ford Ranger with a combination of aesthetic and performance upgrades, all at an affordable price. A true carbon fiber wide body system made of 100% aerospace-grade carbon fiber adds 10-inches of width to the truck and allows for fitment of up to 35-inch tires and up to 12.75-inches of suspension travel.
The ProRunner Series 1 package long-travel suspension system includes +3″ wider upper and lower control arms, billet extended tie rods with FK rod ends, extended CV axle shafts (4WD trucks only), front hub centric wheel rings and rear wheel adapters with black lug nuts, all designed and manufactured by APG. The ProRunner Series 1 package does NOT include wheels, tires or shocks, allowing owners to choose based on their personal preference. The Series 1 package can be applied to 2WD or 4WD trucks. All ProRunner body panels and components are designed, engineered, and manufactured in California. The APG ProRunner Conversion is engineered for MAXIMUM off-road performance, without sacrificing on-road drivability.
With 270 horsepower, 310 pound-feet of torque, longer wheel travel and improved ground clearance, the APG ProRunner is not only a blast to drive off-road, but also serves as a reliable daily driver.
Included Components
- Carbon Fiber Driver Side Front Fender (5″ Flare & 1.5″ Rise)
- Carbon Fiber Passenger Side Front Fender (5″ Flare & 1.5″ Rise)
- Carbon Fiber Driver Side Bedside (5″ Flare & 1.5″ Rise)
- Carbon Fiber Passenger Side Bedside (5″ Flare & 1.5″ Rise)
- Carbon Fiber Fuel Door Assembly
- Fuel Neck Extension Kit
- APG Long Travel +3″ Upper Control Arms (Powder Coated)
- APG Long Travel +3″ Lower Control Arms (Powder Coated)
- Heavy Duty +3″ Tie Rods with FK Rod Ends (Heim steering)
- +3″ Front Axle Shafts (Heat Treated 4140 Chromoly)
- Aluminum Front Winch Bumper (With Closeout Brackets)
- LED Amber Side Markers
- Bumper Powder Coat (Fine Textured Black)
- Front Bumper Recovery Shackles (Removable)
- Front Hub Centric Rings 106.2mm – 93.1mm
- Rear Hub Centric +3″ Wheel Spacer/Adapters 106.2mm – 93.1mm 6061 Aluminum
- Gorilla Lug Hardware (All Black) QTY:36
Optional Equipment
- Exposed Carbon Fiber Fender Flares
- Extended 4130 Chromoly Front Axle Shafts (Required for 4WD)
- King Extended Travel 2.5 Front Coilovers with Compression Adjusters
- King OEM Series 2.5 Rear Shocks with Compression Adjusters
- Falcon 2.25 Sport Leveling Shock Package
- Adaptive Cruise Control Sensor Relocation Bracket
- Baja Designs SAE Pocket Fog Lights (amber or white)
- Baja Designs XL Pro LED Front Bumper Lighting Package
- Warn Winch and Factor 55 Flatlink Package
Learn More
Want to know more on how to get your own APG ProRunner Ford Ranger? Check out their website at ProRunner – APG (automotiveperformancegroup.com)
Video
More Photos
Click the photos to enlarge.
About The Author
Jim Oaks is the founder of The Ranger Station, one of the longest-running Ford Ranger enthusiast communities on the web. He has spent over three decades owning, modifying, repairing, and driving Ford Rangers on the street, trail, and cross-country routes.
Since launching TheRangerStation.com in 1999, Jim has documented thousands of real-world Ranger builds, technical repairs, drivetrain swaps, suspension modifications, and off-road tests contributed by owners worldwide. His work has been referenced by enthusiasts, mechanics, and off-road builders looking for practical, experience-based information rather than theoretical advice.
Jim’s hands-on experience includes long-distance overland travel, trail use, drivetrain and axle upgrades, suspension tuning, and platform comparisons across multiple Ranger generations. The content published on The Ranger Station is grounded in first-hand experience and community-verified data, not marketing claims or generic specifications.
