PonyUp
- Jul 21, 2011
- 2
- Texas
- Ford
- Engine Size
- 2.9
Good morning.
Thanks for responding yet again Unoleisu.
Three of the wires are missing about 3 inches of wire. Will have to add wire. Since you use a lighter...You think one of those long lighters made for fireplaces and grilling woulds work? They run around $5 I think.
Here is something I found about "tinning". Not sure if it is the same as what was referenced by previous poster.
>>>>"Melt a little solder on the tip of the iron.
This is called 'tinning' and it will help the heat to flow from the iron's tip to the joint. It only needs to be done when you plug in the iron, and occasionally while soldering if you need to wipe the tip clean on the sponge."<<<<<
Will look for a youtube video with helpful visuals.
Hopeful the Shop manual I bought will tell me where those last 2 connectors go. Media mail so not sure when it will arrive.
Thank again everyone.
