CamTheHedgehog
ASE Certified Tech
431
Charlotte, NC
Ranger Edge
4.0 SOHC
Torsion Bar Max Crank (Pre-2008)
Professional Dingus At Work
Thanks for the link. It saved me a bunch of searching, comparing and wondering if they are legit. It's ordered and now I'll have both sides for this summer. My third eye sees some sheet metal work in my future.
Now to hit up Tractor Supply and snag a small chunk of 18ga steel for any inner wheel well repair that is needed. I haven't really looked but I'm sure there are some spots it will be needed.
I have a 120v mig welder, some magnets and a couple clamps but I may hit up harbor freight and grab a few more clamps just so I have enough on hand. Must remember to try to find a spot weld drill bit and possibly a seam buster also.
You can never have too many welding clamps and magnets! Ask any fabricator.
lil_Blue_Ford
6,328
Butler, PA, USSA
4.9L
You’re welcome! My first thought when I saw your post was about where I got my stuff. I’ve ordered from LMC and I have got some Amazon/EBay sheet metal. When I refurbished my F-150 years ago, I ended up buying everything from Raybuck, actually called them because a couple pieces I needed they didn’t have listed and they said they could get the stuff but they didn’t list some parts because they didn’t sell many or shipping was crazy (like a new core support). Not a problem for me because I live close enough I just picked it all up.
JoshT
1,908
Macon/Fort Valley, GA
Carnage confirmed. The brand new CV joint I installed on the front driveshaft is toast. Can't blame it on the joint, I'm pretty certain that it could have been avoided. When I reinstalled the joint on the truck I tightened the bolts for the joint well. I think after rolling a few miles the CV seated in the flange better and loosened up the bolts. That allowed gaps between the sections of the joint and when the grease got warm/hot, the rotation slung all of it out. Boot was intact, but grease was everywhere except in the joint and the bearings were galled.
New joint ordered and lesson learned. After installing the new joint, check the bolts a few times within the first couple short drives. Also got things torn back apart to swap out the AC condenser and compressor tomorrow. Hopefully both of those will be fixed this weekend. That'll just leave figuring out the high speed only for the blower fan, I've already replaced the resistor with no change.
ben_2_go
381
Third rock from sun
Furd
2.5 (4 Cylinder)
2.5 Scrap
235-75-R15
None at all.
New mass air flow sensor with housing.
Maritime Drag Racing
901
Sydney, Nova Scotia, Canada
355 Chevrolet
2" drop rear shackles
27 X 5 X 15 Hoosier front - 9X30 Hoosier rear(slicks)
Race it - Break it - Fix it - Repeat
What I did today to my Ranger today - We're in a new class this year(Super/Pro) so I had to make a new T-shirt design. Only a couple of tenths quicker than the minimum ET for the class so I should be leaving first most of the time which is what I prefer. Hence the "catch me if you can" line LOL. I even get to use a delay box this season....
JoshT
1,908
Replacement A/C somponents installed, cooling system reinstalled, and bleeding coolant system.
Tomorrow dad will probably finish bleeding the coolant system and attempt to charge the A/C. I'd be working on it myself, but hopefully new fan motor for my house AC system will be here tomorrow and I'll be getting it installed. I hopefully all goes right on both fronts, otherwise I'll be back in there again. Weather is approaching the territory of needing AC for part of the day and I don't need to spend any more money that stuff right now.
superj
2,771
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
My youngest son took it to work because he is picking up a jeep rack after work and it wint fit in his mazda
ben_2_go
381
Third rock from sun
Furd
2.5 (4 Cylinder)
2.5 Scrap
235-75-R15
None at all.
Ran a few errands in the ole Strangler this morning and then parked her for a nap while I worked on and test drove the ole Jimmy 5500. I'm trying real hard to like this truck after all the problems it has given me since buying it.
ericbphoto
Overlander in development
TRS 25th Anniversary
16,837
Wellford, SC
6"
I hate to say it. But, if you have to "try" to like it, its a lost cause, trade it for something that makes you happy when you look at the driveway.
ben_2_go
381
Third rock from sun
Furd
2.5 (4 Cylinder)
2.5 Scrap
235-75-R15
None at all.
I overall like the truck. Wish it was the version with the cat diesel and 7 speed. The 8.1 is a troublesome monster, and right after I got it at the first of Feburary, it developed fuel pump problems. The fuel pump module is NLA and sourcing one has been a two month ordeal. My fuel pressure still isn't right. I don't trust it, and yeah, when I know it's not going to die as soon as I sell it, I'm selling it.
CamTheHedgehog
ASE Certified Tech
431
Charlotte, NC
Ranger Edge
4.0 SOHC
Did two things, one yesterday and one today.
Yesterday, I replaced my shift tube bushings to fix the floppy column shift, they were basically just dust. Because I know the tube itself can wear out as well, I bought the Dorman kit with tube and bushings and figured I'd replace it all, as the truck does have 250k on it. That was not a good idea as I soon discovered....
As far as the wear on the original tube, I was wrong about that. Yes, the shift tube has a little tiny bit of wear where the interlock pin goes, but I smoothed it out with a file and it was fine. The new tube was a joke. Easily two or three millimeters of slop between the plunger and tube, as well as a horrible casting quality and finish. Even the old tube only had maybe one millimeter of play in it, AFTER 250k. The part was a joke. I didn't put it in, I just cleaned and re-greased the original tube, put new bushings on, and put it all back together and it feels great.
You can't get good quality parts anymore, I swear. I find myself going to pull a part/LKQ more and more often, as the used genuine old parts are better than the new garbage that is all we can get. :pissedoff:
Today, I put together a little tee adapter for the upcoming oil pressure gauge install. I didn't want to spend $30 on the sandwich plate, and with the factory sender in a good location I just made up a fitting to allow me to tack on the new sensor while keeping the original as well.
Uncle Gump
Token Old Guy
13,648
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Been a minute or two since I've looked... but I don't remember there being a bunch of room for all that.
I also remember the days when dorman stuff was first rate. Not so much any more.
CamTheHedgehog
ASE Certified Tech
431
Charlotte, NC
Ranger Edge
4.0 SOHC
I found the cause of the clicking/grinding noise….. CV boot has left the chat. About 3 millimeters of up and down play in the joint now. Any suggestions for brand of joint? I know dorman makes one but I haven’t had the best luck with them lately.
sgtsandman
Aircraft Fuel Tank Diver
12,945
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I found the cause of the clicking/grinding noise….. CB boot has left the chat. About 3 millimeters of up and down play in the joint now. Any suggestions for brand of joint? I know dorman makes one but I haven’t had the best luck with them lately.View attachment 108810
Not sure if this helps, but these are the brands RockAuto offers: https://www.rockauto.com/en/catalog/ford,2003,ranger,4.0l+v6,1438311,drivetrain,drive+shaft,2308
Trakmotive is the only one to offer a lifetime warranty. That may or may not mean anything. The rest are 12 months or 12 months/18,000 miles.
