G8orFord
803
FL
4.0 SOHC S/C
Just the right size to touch the ground.
I would certainly start with fuel pressure. Also ensure the regulator is operating correctly. Because it happen under heavy load... the regulator is suspect.
If all good there... check timing first. Then ensure it doesn't have goofy none OE spark plugs. Then I would go through the secondary ignition components.
Fuel pressure is good (between 30 and 40 psi) and the regulator is working the way it should so I guess it's spark. It did run a bit better yesterday than Saturday which also leads me more towards spark problems. Saturday was rainy and wet, yesterday was clear. More moisture in the air will cause more issues with spark if there are issues to start with. I'll run through the plugs, wires and distibutor maybe this weekend. Here's some pics of the beast.
It needs a throw-out bearing and an A/C compressor (probably more A/C stuff) and the driveshaft is making some noise. Are there any good alternatives for the stock CV style shaft that'll work with a 4" lift? There a few other little odds and ends that need attention, but overall it's in pretty good shape for a 38 year old vehicle.
RangerFabWorks
The O.G blackwidow67
715
Lexington, North Carolina
302
I bought this truck solely as a parts truck. But I got it running and driving. It still needs quite a lot of work for it to be roadworthy. But she is cleaning up nice. Not sure if I have the heart to cut it up. But I really need a lot of the parts it has.
Rick W
3,908
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Never put off ‘til tomorrow what you can put off indefinitely
looks pretty nice! Clean it up and flip it, and buy the parts you need with the profits
RangerFabWorks
715
302
that’s the problem. I need the cab with the title. And the bed. So I’m cutting up a ranger no matter what.
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
I thought about mine. Havnt seen it in a couple weeks.. but im sure it's still clapped out lol.
ericbphoto
Overlander in development
16,610
Wellford, SC
6"
Drove my ranger to whiskeytown lake again, and took in some sunshine. Starting Wednesday is gonna be that pineapple express for at least 4-5 solid days of rain. Wanted to get out for a bit today. Went for a short walk into nature to see how I can remember my true self.
Beautiful pictures.
1984RESTOMOD
52
midwest
ford ranger
302
2" BODY LIFT
33"
Now that chassis and drivetrain is complete minus driveshafts, I’ve started in on the cab excising cancerous rust. Got seats and heat shields out/off yesterday evening; waiting on floor pans to show up. In the 4th pic you can see old boy replaced the driver side with panel epoxy and spray foam but i’m going to tear it out and redo it. Not the best welder but I plan to do a shit load of tack welding rather that panel epoxy. Any opinions?
ben_2_go
341
Third rock from sun
Furd
2.5 (4 Cylinder)
2.5 Scrap
235-75-R15
None at all.
View attachment 105352View attachment 105353View attachment 105354View attachment 105355Now that chassis and drivetrain is complete minus driveshafts, I’ve started in on the cab excising cancerous rust. Got seats and heat shields out/off yesterday evening; waiting on floor pans to show up. In the 4th pic you can see old boy replaced the driver side with panel epoxy and spray foam but i’m going to tear it out and redo it. Not the best welder but I plan to do a shit load of tack welding rather that panel epoxy. Any opinions?
Make sure there's no gaps underneath that can trap water. Water's surface tension will hold it in a crevice even when it's facing down. That's why my '71 Buick Skylark has so much rust in the body seams underneath. I don't live in the rust belt. I'm to far south for that. My family has owned it since it was new and it's never left the south east.
ericbphoto
16,610
Wellford, SC
6"
Removed the bumper so I could finish welding it and add the recovery points. I like it. Now I just have to get @Rick W to slap some Rustoleum on it.
Rick W
3,908
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Bring it on by! I just bought 2 quarts yesterday.
In case you can’t make it this way, mix the first coat 50-50 with mineral spirits. It’ll run into all the nooks and crannies and gaps, and even the teeny pits in the welds if there is such a thing. Then a double coat about 10 hours apart. When you bolt it up, run some of the 50-50 mix all over the connection points. It will wick into the gaps.
come by and thank me in 10 years, when it still looks new!
Rick W
3,908
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
ericbphoto
16,610
Wellford, SC
6"
Uncle Gump
Token Old Guy
13,480
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Dang @ericbphoto
Those are some pretty serious recovery points.
Your welds look pretty good too.
ericbphoto
16,610
Wellford, SC
6"
I'm getting better. But there's plenty of slop on this project, too. I had issues for a little while after putting a new spool of wire in the machine today.
Rick W
3,908
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Thanks. I'm glad to have it (maybe) finished for a while.
I wish my welds looked like that. Mine are more like a mini version of the Rocky Mountains with lakes and streams below.
