JoshT
1,815
Macon/Fort Valley, GA
HEY HEY HEY! I’m sure they used the cheapest scrap, crap wood they could use when they made these things, but it’s not fake!
And why would I dispose of it? I’ve got almost 69 years of cleaning up other peoples‘ s***
Ah ok, I misunderstood a previous post. I recall you saying something along the lines of it looks like wood but actually metal. I took that to mean it was a faux wood appearance on a metal box.
Rick W
4,031
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Never put off ‘til tomorrow what you can put off indefinitely
No hurt feelings, here, always just joking around. I love history and tradition, I’m one of those folks that if I hit the big lottery, I wouldn’t buy newer stuff, I would buy older stuff. The stupid thing is it worth anything, and I bought it for a step for Lincoln to look out the window, but I’m sure I think it’s a lot cooler than anybody else thinks.!
sgtsandman
Aircraft Fuel Tank Diver
12,764
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
It's a wooden box lined with very thin, galvanized metal. If it's anything like the wood box my orginal cast iron set came in, the wood is pretty soft. I had to replace the lid aready with a piece of pine plank and reenforce some other stuff.
racsan
4,498
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
Got the tires changed out, went with the jeep wrangler rims Ive had for years, looks better than those hhr rims with hubcaps I ran for the winter. Took a lap around the block, we will see if these tires hold air, they had been in storage for a few years and all of them needed aired up.
ben_2_go
352
Third rock from sun
Furd
2.5 (4 Cylinder)
2.5 Scrap
235-75-R15
None at all.
I picked up the C5500 Topkick today. Just in time for the Stranger to crap it's 4r44e transmission for the third time. Only 260,000 miles and none of those miles have been hard or abusive. Maybe I should have treated it more like a $2 hooker than my daily rider. :ROFLMAO:
sgtsandman
12,764
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Replaced the right tail light. So the 2011 is pretty much back to normal.
In other news, it looks like it's getting about time to replace the rear parking brake cables. When the temperature drops below freezing, the pedal doesn't return all the way to the disengaged position without help. She's starting to show her age and needs some attention.
Rick W
4,031
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
hey, if she’s only two dollars, you can ride her all day long!
JoshT
1,815
Today was back on the parts ranger, but I did drive the '99 over there to work on it.
I pulled the rear axle and leaf spring assembly. The exhaust was saved in hopes that I can use parts of it with the V8 swap, looks like an aftermarket 2.5" dual system that someone welded in instead of bolting in. The hitch was removed so dad can use it to make a hitch for pulling trailer behind his tractor. Don't need it now, but also snatched out the driveshaft for future use.
After doing all that I figured out I won't be able to use the axle like I intended. I thought it was a 3.73 and I was going to pair it with the Explorer front diff in my V8 swap. Turns out it was a 3.55. Still needed to come out since I wanted the leaf springs to replace the Explorer leafs that are currently in the '99. I'll still be keepting the axle, I might be able to put it to use in the '85 Ranger. The axle tag says that has a 4.11 (doesn't match door) and I don't think that will be a good match for its engine and tire size.
Only things left are to pull airbags, load it on a trailer, and pull the front wheels. Tail lights look decent so they might get saved for dad's Ranger just in case, I'd like that style light (red & clear, no amber) on mine but different bed styles. I think my BIL said that he wants the trans cooler, radiator, and/or condenser. He might be able to use the trans cooler on his truck, but I don't know what he's going to do with the other two since he has nothing they will fit. I don't need them so he's welcome to them if he wants to remove them.
Good luck with that. This was a southern truck and I had to cut the intermediate cable to get them disconnected. Once that was done the connector where they split came right on off with a pair of vice grips and a hammer.
For a northern truck, you might want to start spraying it with the penetrant now.
Rick W
4,031
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
“Spray,” maybe. “SOAK” is my vote…
sgtsandman
12,764
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
The 1998 wasn't so bad when I did the work on it but it had drums as opposed to the disc/drum system the 2011 has. I might need to at least partially slide the axle shafts out on this one the get enough access. The hubs in the way of everything with that parking brake design.
JoshT
1,815
Had a little bit of daylight left after work so was back on the parts Ranger today. Got the air bags pulled. Got a few other odds and ends pulled. Still had daylight left...
I'd decided quite a while back that I wanted to save the interior plastics to redye for a color change on my truck. I'd grown tired of the light gray stock interior, though it is currently getting a second wind. I'd already pulled most of the plastics as well as the cluster and radio months ago. Had started to pull the dash then decided that it was too much work and I'd dye mine in place when the time came. Well having some daylight left and nothing left to loose, I finished pulling the steering column, disconnected the wiring harness, and proceeded to sratr removing the dash. When I finished for the day it was ready to come out except for one harness commection I missed for the safety restraint system control module, the box under the cup holderson the trans tunnel. Next time I'll get that loose, pull all my parts out and be ready to scrap the rest. If all goes well it'll be gone Saturday and get a few bucks back in my pocket to pay for miscellaneous swap parts.
17,963
SW Iowa
Drove it to pick up my kid from daycare which he really likes last night.
So he walks out, sees it sitting among all the mom mobiles and proclaims "you drove the ranger!"
And then he spins around and punches me right in the crotch in excitement. :shok:
Perfect way to end a crappy week.
ericbphoto
Overlander in development
16,732
Wellford, SC
6"
1984RESTOMOD
62
midwest
ford ranger
302
2" BODY LIFT
33"
That looks real nice.
Thanks - Still have my 3D models if anybody needs some. Will probably make a slight revision and lengthen the gusset and add a collar around the radius if so. Can fab them or send the unbent pieces of watterjetted sheet metal
