Vacuum leak
vbrad511
5
Springfield, Illinois
Oreilys and Autozone both can scan here, any of their stores.Not sure about Advance or Napa.
AgPete139
09/2014 OTOTM Winner
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
Hm. Well, not here. Good to know. Where are you ?
SenorNoob
632
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Apparently not relevant to the OP, but I had exactly the same problem once right after it backfired on startup.
Turned out I blew a crappy vinyl vacuum cap off the very bottom fitting on the intake..
There is no way to see it from above. Or the side for that matter. I just had to feel for the air being sucked in.
vbrad511
5
Well the issues are not resolved. Truck runs much better, but still throwing all 3 O2 codes and the purge system code. Senor, was that cap on the plenum, fuel rail, or the actual intake under everything else?
