Tires/lifting
tjs4x4
ID
Guess its time to start searching for a lift kit then lol.
Maverick
FoMoCo MoFo
17
Eureka, California
truckaddons.com offers a 4 inch lift for your ex for $218.99, then add nothing to it... b/c the camber bushings are cheaper at napa, bilstein shocks are better then skyjackers, and buy stonecrusher steering.
i edited this post to try to make it easier, it was really wordy at first.. lol, idk if you saw the first one or not. lol
http://www.truckaddons.com/Catalog/subpages/skyjacker/skyjacker-ford-47.htm
The lift kit metioned in the link above is not a 4" it's a 2". If you go any larger than a 2" you are going to need drop brackets. If you are just looking for a mild but quality lift to clear bigger tires, go with the James Duff 2.5".
tjs4x4
ID
I do want the 4" lift now lol! What r drop brackets and how do they fit on?
4.0B2
151
Walls, MS
4.0 v6
drop brackets bolt in the place of the stock brackets that old the "sides" of the ttb axle on. they drop down the inner side of the axle so the whole axle is dropped down for the lift.
tjs4x4
ID
4.0B2
151
Walls, MS
4.0 v6
http://roughcountry.com/suspension/4wd-ford/ranger_83-97_4.html
is the "plate style lift", the one i have... the cheapest way out for 4 inch suspension kit. the problem is the drop plate. now if you can buy this and the skyjacker brackets used, you are doing pretty good... but still, the Rough Country is not the best option (you get what you pay for)...
the james duff kit is a lot more money for less lift really, but an amazing kit..
on all kits but maybe the james duff you need softer springs and address the steering.
http://www.cardomain.com/ride/504857/1994-ford-explorer-eugene-or-us
there is a nice ex on 33's and the build on it using f150 coil spacers and james duff shackles. it sits nice on 33's with 2 inch suspension and 2 inch body... it looks nice tho
the spacers http://www.therangerstation.com/tech_library/factoryspacer.htm
and the shackles (warrior not JD) http://www.jackit.com/shackles/shackle_ford.htm
tjs4x4
ID
So if I go with the shackles designed for the explorer AND the spacers, will it still be a 2" lift?
4.0B2
151
Walls, MS
4.0 v6
i'm assuming so b/c that's what that guy is saying, he has a 2 inch suspension lift.. personally i have a b2 and am just going by what i read online
4.0B2
151
Walls, MS
4.0 v6
those type of add a leafs wont work correctly to really lift it when the spring is under the axle. it almost works as a lowering block i think...
the front on either kit would work. but you still have an issue with the rear
tjs4x4
ID
Darn. I saw two shackle kits, but they said it would only raise the rear 1 and 1/2 inch. That wouldn't sit too well with the front being 2" higher. I'll have to keep looking.
4.0B2
151
Walls, MS
4.0 v6
does your truck sit level now?
get us some straight on side pics of the EX
tjs4x4
ID
As far as I know it does. I'll go take some pix.
tjs4x4
ID
