spark plug wires to distributer
Haha. It depends on the situation. I had a bad in-tank pump in my '86. I could literally drive across town and it would die at the last stoplight. Wait a while and it would fire right up, drive some more, until the high pressure pump heated up again. So yes, it COULD run with just the high pressure pump. Mine ran 100% great until that last 10 seconds where the impeller in the pump stopped turning and lost fuel pressure.
It depends on your truck if it would actually work out this way or not. I am just telling you what my real world experiences are rather than how something is SUPPOSED to work.
you must just be lucky. if my tank pump is out it won't start. end. of. story.
kimcrwbr1
46
maplevalley WA
2.8l
Like I said plug the relay in and take a sissors or small flat screwdriver and push each wire in as far as you can then drive it to the mechanic I bet thats the problem.
Junk Collector
Truck of Month
4,806
Rapid City SD
Probably helps that both pumps are only a couple years old. If you stick around this stuff long enough you will see all kinds of stuff that makes you scratch your head. :icon_cheers:
camobroncII
2.9l v6
come to find out guys it was the inertia switch..i guess it went bad..i took it to a guy across the street he had it done in a day..runs pretty good now still feels like she has no power excellerating but the torques nice..gotta get the exhaust fixed tho does anyone know where i can get a complete exhaust to replace the stock one? its bad exhaust mani back
Can't help you with the exhaust. In a year or two maybe, when I get my 4.0, but I don't have anything right now.
kimcrwbr1
46
maplevalley WA
2.8l
Kool I was hopeing you didn`t have to pull the tank I hope the guy didn`t rape you after finding the problem
Junk Collector
Truck of Month
4,806
Rapid City SD
Take it to an exhaust shop...they will just build it from scratch
yeah but if they can't get a y pipe it costs a bundle to get one made.
kimcrwbr1
46
maplevalley WA
2.8l
A good muffler shop will only change what needs to be changed unless you want all new
Spitfire1975
16
Oregon
2.9
I have been pricing out exhaust. Getting about 120 for Y-pipe. 50 for muffler. 23 for tailpipe. 220-320 for new cats. 2.9 on a BII. Can't imagine a ranger would cost more. so basically a little over 400 for all new.
camobroncII
2.9l v6
he charged 150 and had it done the next day before i was done work..he said it was only 150 because it took him awhile to find it..
camobroncII
2.9l v6
id like to just get what needs replaced replaced but it all looks bad it was a farm truck before my grandpop bought it..so it does have its problem spots probally why i feel like i have no power..v6 running like a 4cyl
kimcrwbr1
46
maplevalley WA
2.8l
pull the codes and let us know what you find out now it is running it could be a bad or dirty sensor. change the oil and filters if not done so yet any auto part store can pull the codes for you
