Salvage Yard Seats - Airbag Safety
rickd353
West Palm Beach FL
Hi All,
Redoing the busted old interior of my 94. Found a set of seats from an 07 in a salvage yard, but they have airbags in them...
Want to make sure they're not going to go off on me inadvertently at some point. The most information I can find says "if there's no power to them, they won't go off."
But up under the rail on the driver's seat there's this canister that says "Warning: EXPLOSIVE MATERIAL INSIDE..."
Do I have to worry about this if there's no power to these seats?
I wanted to carefully remove the airbags, but there's no information about that anywhere that I can find.
I figure people must swap out seats pretty regularly, so there must be some info out there about how to make sure they're safe.
Just having trouble locating this specific answer.
Thanks in advance!
Kelvinf
30
Independence Missouri
Ford Ranger XLT
245/70R/16 Venom Power Terra Hunter
When you say something will only take a couple of hours it usually takes longer.
I installed a set of 2016 Focus seats in my 98. They have the same warning underneath. Mine have no power to them either. No worries in them going off.
superj
2,671
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
they need the electricity to ignite the explosive material so you are good. i swap seats in and out of stuff all the time and have never had an airbag go off. i just did seats in my 05 mazda6 sunday
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i will refrain from frightening you.....on this all hallows eve....
rickd353
West Palm Beach FL
Thanks so much for the reply -Those look awesome!
rickd353
West Palm Beach FL
Ok, awesome - thanks! Just the info I was looking for. Gonna get these cleaned up and installed then.
rubydist
865
Denver
Ford Ranger FX4
The best solution is to put a jumper across those 2 pins on the connector to the airbag - that way there is not even a chance of static electricity buildup causing the bag to blow.
rickd353
West Palm Beach FL
Thanks a lot for the reply!
snoranger
Professional money waster
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Side impact airbags weren’t available on a Ranger until 2010… those would be seatbelt pre-tensioners. The small explosive pulls the seat belt tighter in the event of an accident.
rickd353
West Palm Beach FL
Thanks for the reply! Good bit of info - yeah, ok... I could see the little explosive thingie attached to a cable that goes to a spring-looking thing near the seat belt tensioner under the seat...
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
8,807
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
The seats look good.
TdI_Ranger
ASE Certified Tech
OREGON
TDI
We're these difficult to install, and how much modification did you have to do?
Thanks
Kelvinf
30
Ford Ranger XLT
Thanks
I cut the tracks off of the Ranger and Focus seats and then welded the Ranger tracks back onto the Focus seats. Removing the tracks took the most time. Its an all day job but worth it.
Kelvinf
30
Ford Ranger XLT
Post some pics when you get them installed.
