- Jan 2, 2001
- 15
- Age
- 40
- Lancaster, Ohio
- Chevy 3500HD
- Engine Type
- V8
- Engine Size
- 6.6L
- 2WD / 4WD
- 4WD
- Total Lift
- 5"
- Tire Size
- 35"
A few years back I swapped in a manual transfer case. I got it from a local PnP and have had zero issues with it's performance.
Last winter in Ohio we had a pretty nasty February and I used 4WD a lot. I leave my hubs locked all winter. When running 4WD at close to highway speeds I get a nasty vibration and rumble that is not constant, but will go away a second, then come back. If I shift back into 2WD it will go away.
Weird thing is, if I run hubs locked 2WD I don't hear it. If I run 4WD with the hubs unlocked I don't hear it, it is only when I have the hubs locked and in 4WD.
This is my DD and I am afraid to run it too much with this noise. Winter is fast approaching. It is loud enough that I know it is not good to continue like it is, and I am afraid of a catastrophic failure on the highway.
The only other thing worth noting is back in 2006 I was hit and had to replace the front pumpkin, but I reused my old gears and just changed out the axle beam. This shouldn't affect it, but thought I would throw it out there.
Thanks!
Thanks!
