Rangebe...version 2.0
-Nathan-
39
Saskatoon, SK, Canada
HO 5.0 / 7.3 PSD
Thanks boys. Didnt do much this weekend, but did manage to clean the shop, and get the rear driveshaft mocked up. Found a random spicer shaft at the junkyard with a 1350 CV and flanges.
My Sterling 10.25 is an early one (1980's) and hence has what is termed a 'short' pinion. The housings and everything are identical for all the Sterlings, and you can throw 10.5 gears from a newer Super Duty in them, as well as running the long pinion gear set. When I order my gears, I will get a long pinion set. The later (1990's) Sterling 10.25 had what are termed 'long' pinions. The long vs short is referring to the splines on the end of the pinion for the yoke/flange to attach to. My Sterling had a short pinion with a yoke, and I hate yokes. I got a flange from a 2005 Sterling 10.5, here they are side by side.
Short yoke
Here you can see, there is almost a 1/2" more of spline in the long version flange.
Here is the shaft, I cut the slip section apart and cleaned it up, and trimmed to approximate length
and tacked together for mock up
And under the truck. I need to rotate my pinion down just a hair (havent welded perches on yet, was waiting to mock up DS)
Because Im running a CV and due to the extra length of the M5OD-R2/BW 1356, it gives me lots of DS ground clearance.
The slip section of this shaft is pooched, however the flanges and CV are in awesome shape (would just change out for new u joints). Ive been toying with the idea of just ordering a new slip, getting everything to the right length, then having the machine shop weld it up as true as possible/balance it...this should save quite a bit of $$ rather than having a whole new shaft made .
And a pic of the whole rig on its wheels for $hits and giggles, its got a mean forward rake, when its done it will be a couple hundred pounds heavier in the rear and will level it out.
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
AgPete139
09/2014 OTOTM Winner
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
Awesome update, Nathan.
-Nathan-
39
HO 5.0 / 7.3 PSD
Sorry guys have been busy snowmobiling/wrenching on sleds/built a snowmobile trailer. Finally getting back to this thing.
Got the dash and center bar in place.
And the dash fitted.
Have also been working on the floors, patching in plate where the cage goes through. Time to order more tube, and will finalize the rest of the cage.
Divh
bloomsburg PA
1949
just read all 56 pages this thing is amazing i in love lol can wait to get started on mine
miller time
rockfalls IL
FORD
3.0 duals out the back 4.0
Will the shifter hit the dash it looks close
-Nathan-
39
HO 5.0 / 7.3 PSD
nope shifter doesnt come close at all, it was cut/rewelded to where it is now as to ensure it cleared everything.
ChrisR1S
10/2013 STOTM Winner
MTOTM Winner
Southern Virginia
Mild 5.0
Just read the whole build. Very awesome man, very awesome.
-Nathan-
39
HO 5.0 / 7.3 PSD
Hey boys, sorry no real updates, have done some more sheet metal work but have been sidetracked. I am currently building this monster, should be running this weekend. 2007 Suzuki RMZ 450, bigger bore/stroke/high comp/valved head etc.
As soon as it is done Ill be back focused on Rangebe!
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
that's how i am. i start something, get distracted, then start back, then get distracted.
Tankmbt
Ugggggh! Read so many pages and it's not finished yet? This thing is already bad ass, can't wait to see it all done.
rangerguy1996
I want to see this thing done badass truck man
-Nathan-
39
HO 5.0 / 7.3 PSD
Starting to source parts for my single swinger steering setup, and hydro assist. Stay tuned, just need to get through this summer!
-Nathan-
39
HO 5.0 / 7.3 PSD
Ok, time to get back on this.
Busted out the engine hoist to test droop. Its ridiculous.
Got my heims from RuffStuff to start sorting out my steering. Planning to run a single swinger, will see how the geometry pans out.
Got the springs out and frame on stands, to start on the steering.
Drilled the knuckles to 3/4", not sure if Ill double sheer the knuckles or not. The heims at the knuckles are 7/8 x 7/8 with stainless steel safety misalignments.
I am currently working on the pitman arm and swinger, will have more to post this weekend.
