Rangebe...version 2.0
-Nathan-
39
Saskatoon, SK, Canada
HO 5.0 / 7.3 PSD
Getting closer to being done the cage. Got the internal cage to engine cage outriggers sorted. Cut/enlarged holes through the fire wall to gain access to A-pillar tubes. While it doesnt look like much, it was quite a bit of work to get it all to fit and keep the stock wiper linkage intact.
And you can see where to the tube passes through the firewall into the engine bay.
Need to start plating frame/designing engine cage/coilover mounts.
4.0B2
151
Walls, MS
4.0 v6
what do you think you're overall weight will be? completed..?
-Nathan-
39
HO 5.0 / 7.3 PSD
hoping to be around 4400 pounds max.
036speed
02/2013 OTOTM Winner
44
Akron Ohio
F-250
351
Solid Axle Swap 4x4
6"
I need to weigh my truck someday. I thought I would be in the low 4000s, but you have cut out a lot more weight that I have.
However, I have zero tubing...
PlumCrazy
2014 Truck of The Year
179
Millersport, OH
Solid Axle Swap 4x4
He has added a lot of tube though. lol
Im over the 5500lb mark.lol
Sent from my XT907 using Tapatalk 2
-Nathan-
39
HO 5.0 / 7.3 PSD
Yeah added lots of tube, but Ive gutted everything, and stripped speakers/wiring/carpet/all interior trim/insulation/wiring/old mud/bed/etc. I would dare say my rear cage is marginally heavier than a stock short bed. Hoping to be under 4400...will see...
036speed
44
Akron Ohio
F-250
351
Solid Axle Swap 4x4
6"
wizkid00104
13
West Newton/Penn Hills, PA
2.3L/5.4L
Fiberglass fenders helped...
You could fill your tires with helium!
How much do those coil overs weigh? They look fairly light.
Sent from my iPhone
kroussinoffroad
October 2011 OTOTM Winner
14
marquette, MI
Ferd
4.6
my explorer weighs in the 90 pounds heavier and the mazda was at 4770 I think you should be easily under your 4400 mark since I have a lot of stuff that is unneeded on mine
-Nathan-
39
HO 5.0 / 7.3 PSD
Been busy, havent posted in a while. Lots been done, and even more than what pics I have.
Engine cage started, goes through firewall in 3 places.
coilover mounting
and coilover in position.
Mounts are actually all done on this side, just dont have a pic. Will post more when other side is completed, and then need to weld the cage fully, its just tacked for now.
Kyle M.
GOING FOR BROKE
9
Howard City Michigan
Looking good!
MountainMike
84
Canada
245 CID
2"
31"
The fun begins where the pavement ends
This monster, that's what happens when I go away! It looks fantastic Nate!
-Nathan-
39
HO 5.0 / 7.3 PSD
Thanks Mike!
This is the first time the truck has supported its own weight in a year and a half, very pumped. Still have to make the removable braces in the front of the engine cage, and a couple more down tubes, but shes getting close! I think my spring rates will be just about bang on. This is about ride height, and the upper coil retainer is turned up most of the way, so as weight is added Ill just turn them down to where I want them.
And scored these at the junkyard; MINT black gen 3 Ranger hood and front fenders (wrapped them in shrink wrap to keep the grinding dust off). Im going to have 2 sets of skins for the truck; fibreglass for pre-running and go fast stuff, and stock steel bedsides/fenders cut to fit the wheels for trail-bashing.
Peace.
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
