rurouni20xx
- Jan 13, 2009
- 0
- natchitoches, la
- Ford
- Engine Size
- 3.0L V6
i was leaning somewhere to that design, just wasnt sure what size filter to use and such. i never thought about running the oil cooler and filter together tho, makes sense i just figured the flow restriction from the filter would starve other components, guess not if i have a good filter. thanks for informing me about the oil fitting on the rear of the engine, didnt know it was there, ill see how easy it is to get to (or not to get to, prob do the fittings b4 i reinstall the engine.) im going to get an oil fed turbo, the sealed bearing ones you change too much, bearing get hot and spin too easy/soon. i hated changing those things, oil fed turbos are a lot more reliable. thanx for the info, im still going to look for a larger oil pan tho, ive been digging and finding some really interesting things here and there. i may never find one, but ill still look just incase, just like i found the custom mafs, i think i may be able to find something that will work/help out. thanx for the info. one more thing, anybody ever experimented/have experience w/ the multiple blade aluminum fans? im looking at a 7 blade flexalite, any info on those?
