THE H.P FREAK
- Jan 8, 2009
- 3
- WINDSOR, ONTARIO, CANADA
- FORD
- Engine Size
- 4.0L (245c.i)
One more time for you slow learners
Only when your revving the piss out of your engine. Most stay around 2500-3200RPM while driving. My 2400CFM electric fan does that CFM rating ALL THE TIME.1) Mechanical fan/clutch has much higher cooling capacity than e-fans
Well in 20 years I've gone through about 4-5 clutch fans. In the last 11 years I've been running electric fans I have not had one problem or failure.2) Mechanical fan/clutch has much higher reliability than e-fans.
Well that doesn't explain why I pick up MPG, H.P/TQ, and quicker 1/4 mile times with a electric fan.3) E-fans loose efficiency due to mechanical to electric back to mechanical energy conversions
What most don't understand is once you get up to cruising speed, which around here is 40-50KPH the cooling fan, electric or mechanical is useless. There is way over enough air flow coming through the rad itself from the forward motion of the vehicle cutting through the air. If your vehicle starts to overheat in the 1-2 minutes your sitting at a red light waiting for it to turn green, then your vehicle has other cooling issues. I have not had my electric fan on since late September. That's 4 months I haven't had to waste energy and fuel spinning that stupid clutch fan around. I've got 2 more months before I even have to start thinking about turning it on. I daily drive (hard), TOW, HAUL, and RACE at the DRAGSTRIP. In my applications the electric cooling fan(s) has basically beat the crap out of the clutch/mechanical fans. Sorry if you can't except this but in my case and a ton others here in town and all over the internet it has too.
