Outrangerous update
Things are great. I've put about 300 miles on the truck and it runs great !!
I've only checked the mileage once and it can out just short of 20 mpg, not to shabby. I haven't had any problems to speak of, the side pipe is rattling on the frame a bit (needs a small spacer). I can't seem to get the idle to settle down, it idles fine in neutral but when in gear I starts to lope . It's annoying. I'm going to take down to the auto store and have them read the pcm and see if it has thrown any codes, I reused old O2 sensors and maybe they aren't working correctly
not sure. It's alot of fun to drive and the side pipes sound great. I don't notice any difference in handling at all (except at full throttle from a stop) woooooooooow. No problem breaking these tires loose. I had to go through state inspection here in Pa. (yearly) and eveything went fine except I found out that Pa. does not allow the flexible exhaust pipe, (have to use the flex pipe with the braid on the outside). i used a short piece (14") between the exhaust header pipes to the side pipes. The shop let it slip by but told me to swap it out with the correct pipe when these burn or rust out, also needed new front rotors ( go figure, they only had 235,000 miles on them).
Been working on some scratch removal on the bed, racked up quite a few scratches over the last 11 years, starting to look alot better. This swap has been alot of fun and in the end was well worth the effort. Thanks for all your input , encouragement and info.
Still have a crazy burnout video coming ASAP. My wife doesn't understand the need for such a thing. Can you believe that.
