Ok, so to fill you guys in on what's going on, I decided to finally swap in the injected motor and 5 speed.
Somehow I mismeasured, and the 5 speed is the same length as the TK4.
I mean exactly the same, 33.5 inches between the bellhousing and the center of the ujoint on the slipyoke, with both slipyokes extended the same. *about a 1/2". So basically, I have the old motor/trans pulled, along with all the old wiring and stuff. I also ran a check for codes, and it came back with none.
127,000 miles on it, and aside from a small valvecover leak, it looks to have been very well maintained. Shiney sparkplugs and a newer looking wix filter. I'm excited to get this thing in there.
This was why I finally pulled it apart. The clutch was slipping pretty bad after the last trip through the busy.
Notice the mud packed between the fingers and cover.
New clutch and slave in the mazda combo.
I'm guessing a m50d, though I don't know what variant. The shiftrail plugs look good, no leakage.
Poor little bastard.
And that's it for tonight. I need to run a return line for the fuel, swap the drivers side motor mount, and maybe make a passenger side. The mounts are at a v type angle to each other, rather than flat like the ranger ones. The drivers side looks like I can bolt up the old one, the passenger side, the alternator bracket is in the way. This should be a fairly simple fix though, and it's on to wiring.
The plan for tonight is to kick back with the chiltons and see what kindof trouble I can get myself into.
