Jeep Commanche axles
Southern_Trendkill
7
Jacksonville, FL
Mercury, Mitsub
144 "Thriftpower", 2.4 MIVEC
I'm looking at a SAS for an 88 ranger. Right now I have the d28/7.5 combo. I found a Jeep comanche in the junkyard that has both axles in excellent condition. I know it has a d35 rear and d30 front. If I want to run 33's, with these axles handle it? Also, if I do an engine swap later on, will they handle the increased power?
86ford
rocky river ohio
FORD
4.0, abused and misunderstood
Your 7.5 is a stronger axle that that d35 rear. A locked d35 is a time bomb without the super 35 kit. I am NOT a jeep guy BUT I would not think the d35 would be in the rear of a Commanche.
the d30 is good up to 35s usually unless you beat on it. But when you beat on things anything is possible.
86
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,864
Pittsburgh, PA
2.3 EcoBoost
1.5"
"220, 221, whatever it takes."
I'm pretty sure the Comanche used the same axles as the Cherokee. The Comanche did offer a payload and towing package that included a "heavy duty" rear axle that was a Dana 44. So you will find some Comanches with a D44 but the vast majority will have a D35.
c_note
September 2009 OTOM Winner
back in San Diego, CA
Ranger/Explorer
4.0 sohc
33s are the largest you wanna go with on a dana 30. just throw an 8.8 in the rear.
Roger
Tooele, UT
2.3
Comanches had the D35 rear. Except the early year Metric Tonne trucks which had either an AMC 20 or a D44.
Mechanickid
4
Martinsburg W.V
2.9
Whats wrong with an 8.8 and a d44? thats a good combo, cheepthrillsBII used to beat the snot outta his....
JohnnyO
Moderator Emeritus
2,864
Pittsburgh, PA
2.3 EcoBoost
1.5"
Nothing, the problem is finding a Dana 44 that's the right width.
Early Bronco:
'66-'75 D44, right width, drum brakes
"76-'77 D44, right width, disc brakes, pricey as hell if you can find one at all
IH Scout:
Right width, most have drum brakes, some have discs, either way the bolt pattern is wrong
Currie or whatever axle shop:
Custom built to your specs, pricey as hell
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
It's actually '71-'75 with drums, '76-'77 disc (EB D44).
Anything in an EB before '71 (stock) is a LP D30.
Agreed, keep your 7.5" rear. D35s may make good front axles, but not rears (why not just go that route anyway? that'll handle 33s + your engine swap fine. The D30 will be marginal at best).
liftedredranger
york pa
2.9
I did the same thing to a 90 ranger dana 30 4:56 long arm with ford 8.8 with custom 4link coilover and im running on 37 BOGGERS the axle handle find.
RumpRangerSTX
mt holly nj
73 eb dana44 chevy knuckles out 96 honda pastport dana44 in rear that's what i'm going to run both of them 58in
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Say what ?
passport d44...like a montero.
better off with a 8.8.
i think a d35 ttb would be better bet as well, the 30 is fine but with a ttb truck a waste of time...with a sla chassis or 2wd tib i wouldnt think twice about a d30....but its better to do a d35 in a ttb truck, its too easy not to do it.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Mechanickid
4
Martinsburg W.V
2.9
CheepThrillsBII was running alot more than 33's when he broke his D44 and 8.8.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
he will bust the d44 up with 33's too:icon_thumby:
that is if your driving the snot out of it...
if your pretend wheelin they will never break.
