I think I MAY have exceeded the payload
Tonka
Kankakee, IL
make sure to get RTV at the same time, you don't need a diff gasket, most people just use RTV, personally, i would use both... next time i do my fluid, the gasket i just got will go on, and RTV to hold it in place... just a little now...
so that's a 3.45 8.8 you said? l/s?
No, the one in the pic is a 3.45 7.5" open diff. And while waiting for the local auto parts store to get my U-bolts in, I decided to de-grease the junkyard axle. When I flipped it over to do the bottom, I noticed the plastic diff cover was damaged by the junkyard. Fresh, clean crack in it. So now I need a diff cover for a 7.5". I made a whole thread about Autozone's stupid parts lookup computer system. LOL.
Tonka
Kankakee, IL
I've got a 3.73 Ranger axle I'll trade you for whatever Ranger axle you have, if you come down and get it. We'll need to take it out of my pickup trailer. I can't gaurentee the condition of the brake cables so you'll need to tkae that type of stuff out of your own axle, but the axle itself is good.
I'd be interested in that, when I get the time. I'm guessing it would be about a 600 mile round trip; and I'm sure the junkyards around the Chicago area would have a 3.73 if I looked hard enough. I don't plan another axle swap for a while though. I think i'll be alright with my 3.45. I guess it would be which is cheaper, roughly $200 a junkyard would charge for a 3.73, or 600 miles of gas. I suppose if I can haul the axles on my hitch-rack thing behind my Buick Century and get 34 mpg at 65 mph, it would be worth the trip. I have a friend in Indianapolis anyway.
The axle I took out was given to me by the local junkyard back in 04, and I TOLD THEM 4 OR 5 TIMES, .. AXLE CODE 84!! But they gave me this "mystery axle" with no tag on it and it's WAY off. It's also an 8.8" while the OEM axle is a 7.5".
I was looking at 63-64 mph actual speed on GPS when the speedometer said 55, with no other variables. Same trans, same tires, etc.
Other than the unknown ratio, (with no other variables, the math works out to roughly 3.00 ?? :icon_confused:) the axle I removed has nothing wrong with it, unless it's supposed to be a limited slip. I'm pretty sure it's functioning as an open diff. I lost track of how many times I had to fire up the farm tractor last winter when the stupid thing got stuck in the driveway. The truck was driven once in floodwater about halfway up the diff, but when I got home I changed the oil and there was no evidence of water in there. Oil came out black, not creamy. The new oil I put in said "limited slip" on the jug.
Right now there's no brake hardware on it, (I'll put the junkyard drums on just for sliding around in storage as soon as I get them off the 3.45) and I put a plastic bag over the nipple for the rubber vent hose to keep crap from getting in there, even though it looks like there already is some crap inside the nipple. The plastic bag is secured with baling wire wrapped around like a hose clamp. I also put anti-seize on the threads for the little bolt on top that holds the brake line tee-fitting, and on the threads for the bolts that hold the U-joint thing on. (You know those 4 bolts that require a 12 mm, 12 point box end wrench to remove.)
I'm not sure what I'm going to do with it, but for now it's going in the barn.
The parts store just called, .. my U-bolts are in a day early. :yahoo:
Will
514
Gnaw Bone, Indiana
Toyota
If we trade, I don't care if the axle you give me has drums or brakes on it. It just needs to hold up my water trailer.
3.73 is 8% more torque over a 3.45 and also 8% more rpm.
94xcab4x4
Bismarck ND
RIP 94
chevy cc 4x4 15
6.0
Yeah i think you are fine. This is funny though i was in menards i bought my landscaping bricks and there was a guy back there with a little truck can't remeber toyota, s10, ranger, or nissan 2wd shortbox reg cab. The forklift operater loaded mine onto my 2500 and i had like 3 times the blocks, and he says man that was easy i should have had them do that for me, then he said man i hope my tires don't pop on the way home. Then he asked how come my truck and tires weren't squiting like his were. lol the fork lift operator was lhao as he drove away.
Tonka
Kankakee, IL
Don't get me started, ... I could tell you stories about dumb people all day long. I drive 18 wheelers for a living. Trust me, I've met plenty of idiots out there, LOL
