I need rear seal installer tool for 3.0 v6 1996
javis
Oklahoma City, Oklahoma USA
Hello guys I m going to replace the rear seal for a 1996 3.0 v6 ranger. I have not found the appropriate tool for the job. Could you help me?
franklin2
1,775
Virginia
Junk Collector
Truck of Month
4,862
Rapid City SD
Piece of pipe or tubing that's roughly the same ID and OD as the seal will work. Cut a short piece of it and use a chunk of wood against it to hammer on.
ericbphoto
Overlander in development
TRS 25th Anniversary
16,764
Wellford, SC
6"
That’s how I often install seals. Just need something that contacts the outer rim of the seal real well. You want to push the metal part of the seal. Not the rubber.
pjtoledo
3,006
Toledo Ohio
Fords
3.0 2.3
grease the inside to prevent tears, use anything that works to hammer it in, gently.
trueblue2
East Coast
ford ranger
What is the OD of the seal?
franklin2
1,775
Virginia
rock auto says 4.262 inches OD. ID is 3.465 inches
trueblue2
East Coast
ford ranger
If you can find a piece of 3 1/2 inch pvc pipe,or perhaps a 3 inch pvc coupling,it will work.The od of the 3 1/2 pipe is 4.0 Inches.Not sure of the 3 inch coupling od.A plumbing supply may have the coupling,so take a tape measure or the seal with you.
