I have a Steering box question 😁
RangerRough
10
Edgewood Texas
245 CID
6.5"
35" KM3
I replaced pretty much all my steering components, when doing so, i came accross my drop pitman arm and it barely moving side to side. I have a video, but it wont let me post for some reason. So, my question; Is it normal for there to be slight movement coming from the steering box.
franklin2
1,796
Virginia
Bronco II
No, side to side movement is not normal. It should only rotate. Dropped pitman arms and large tires do aggravate the wear in the bushing in the lower part of the steering box.
Uncle Gump
Boomers gotta Boom
TRS 25th Anniversary
13,676
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
The pitman arm splines onto the steering box shaft... then torqued down to create a swedged fit. There should be zero movement between the pitman arm and the shaft.
ericbphoto
Overlander in development
16,885
Wellford, SC
3.0L
6"
To show us a video, post it somewhere public like YouTube. Then put the link in your post here.
Uncle Gump
Boomers gotta Boom
13,676
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Can't really tell from the video... but you will need to determine if the looseness is between the pitman arm and splines on the sector shaft... there should be zero movement between the two. Or if the looseness is backlash in the steering box... this can't be too tight... there is an adjustment on the top of the box.
Just by the sound though... it kinda sounds like slop in the pitman arm splines. This would require replacing the pitman arm and/or steering box sector shaft.
franklin2
1,796
Virginia
Bronco II
I disagree with the above. You can get that adjustment too tight.
tinman_72
140
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
RangerRough
10
Edgewood Texas
245 CID
6.5"
35" KM3
It’s definitely not slop in the pitman arm splines 🥵 that sucker is on there. I installed all new moog upper/lower balljoints, moog inner and outer tie rod ends, timken spindle rebuild kits, timken wheel bearings inner and outer with timken seals. Brake rebuild kits, r1 ceramic pads and r1 carbon slotted rotors, new warn hubs, and skyjacker steering stabilizer. Nothing moves in my steering now 😁👍🏻😎🇺🇸
RangerRough
10
Edgewood Texas
245 CID
6.5"
35" KM3
Ohh, i almost forgot, does anyone know the torque specs for the inner/outer tie rod ends I couldn’t find a torque diagram. This is my first time replacing tie rods.
Uncle Gump
Boomers gotta Boom
13,676
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Confusing wording on my part... You certainly can over tighten a steering box.
tinman_72
140
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
It's kinda like saying you can't drive without a driver's license. :)
