Extending rear brake line after 6" lift
pillen140
45
winston-salem, NC
need to find a rear brake hose for a 6" suspension lift. i know i can buy the expensive braided ones from skyjacker or where ever, but was wondering if anyone knows of one that will fit from another vehicle that i can pick up from autozone? didnt see anything for the rear in the tech library, just the front. btw, its a '95 extcab 4x4. thanks in advance!
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
I have a 6" lift and didn't need a rear line. Since the line runs to the middle of the axle, it does matter how much I flex, the line doesn't go up or down.
pillen140
45
winston-salem, NC
mine is really tight at full droop. if you strum it, its about an e string on a guitar, lol.
Nater
Bamberg, Germany
Mazda
2.3L
I ran into the same issue on my lift....my solution? I got a really long bolt and JB welded the head of the long bolt to the head of the original bolt....then used a washer and nut....works out fine so far...
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I just built a little bracket to drop the rear factory line down about 3"...never had a problem with it in 5 years.
89PBR96
Pekin IL
I haven't had any issue with My rear yet for the front I used the Chevy 3500 rubber Hoses forget the Numbers but they are in the tech section some where like a 95 ish pickeup right and left side they work great
pillen140
45
winston-salem, NC
btw, for the front lines, the part# someone gave for the one piece front hoses, is completely wrong! the hose itselft is about 2" longer, but it doesnt have the built in steel ext. so they are the exact same size! plus you have to grind down the side where it meets the caliper.
ForOffRoadDriving
18
HIGHLAND, MICHIGAN
FORD
3.0L
brake hoses vary so much vehicle to vehicle that i just went the stainless route, it ended up being about the same price as the rubber hose. i work at a parts store so i spent a couple of days looking through our illustrated books of brake hoses with dimensions, but i couldnt find anything that closely mocked the stock ranger hoses in a longer length.
holyford86
Some guy with a problem
687
Plattsburgh, NY
many
33x12.50R15
For the rear hose,a rear hose from a 1989 dodge ram 1/2 ton 4x4 will work, i've done it. as for the front lines, I used 1989 Chevy K2500 hoses there are two choices for GVW choose the 8600# one.
... i work at a parts store so i spent a couple of days looking through our illustrated books of brake hoses with dimensions, but i couldnt find anything that closely mocked the stock ranger hoses in a longer length.
NAPA prolink is a wonderful thing, I searched by end type and looked at lengths and styles to come up with what I use.
pillen140
45
winston-salem, NC
I have access to napa prolink, where is there a spot to put end types and lenths in there?
holyford86
687
Plattsburgh, NY
many
33x12.50R15
I should have known someone would ask, I just re attempted it, for about 20 minutes, with no luck. I searched brake hose, got every one in the site and by some combination of selections I got an end type selection, it was about a year ago though. I just searched for a heater hose with a very specific bend that I needed and got diameters and lengths though... Well... I'm off to go stuff my foot in my mouth apparently, dammit... A search of the brake parts I mentioned, by application does give me dimensions and end types though...
