as i said before, the only critical joint that needs to be fabbed is the connection between motor and compressor....so i guess "easier" is subjective. as for the money, all these parts can be found in a junkyard. electric motors go for nothing and if you could find a turbo with a wrecked turbine you could get it for dirt cheap. i never said this would be more effective than a turbo...not sure where you got that idea
you also ran lean and burnt the crap out of the inside of your motor....ive seen the pics
you can change the pulley diameter of a centrifugal blower to make boost down low just like you can adjust a turbo or roots blower to do the same. they are generally high-reving blowers, but they can make boost under 2,000 RPM....especially if its only 2PSI we're talking about. granted we wouldnt be using a pulley for our application, we'd have to use gearing. and a 1HP motor turning 4,000RPM wont use any more juice than a 1HP motor turning 2,000 RPM. 1HP is 1HP...they will both draw slightly more than 1HP from the alternator.
maintainence will be nill. electric motors are far more reliable than gas engines. there are EV conversion guys out there with over 100,000 miles on their motors on the original brushes....and those motors put out many times the power and RPM that this application needs. even the blower motor in my truck has survived 130,000 miles and its a lot cheaper (with its copper bushing bearings) and thus, less reliable than a "real" motor. and replacing brushes...even if its every 30,000 miles, takes a wopping 10 minutes.
you seem vehemently opposed to the idea for some reason, but you have yet to come up with any real reasons why it shouldnt be done. you keep making excuses but none of them hold water. is it so hard to admit that this might be vaguely possible?
