Started by cutting some tube for the rear support of the mounting plate last night.
Then threw the plate on top, leveled it up, and hard tacked it for mock up.
Bent up some toob
Cut to size (yes, I wasted a lot. Story of my life.)
Tacked in place. While all of this was together, I tacked the mounting plate to the rear support and traced the front support profile on the bottom of the mounting plate.
Pulled the mounting plate and rear support off and burned in the front support. While they were out, I burned the mounting plate to the rear support.
Cut the plate to size
Installed and tacked in place. You can see I ended up cutting the outer tabs off of the mounting plate. I want my stinger to tie into the front support rather than just weld onto the top of the mounting plate. Figured it would look cleaner/less of an 'after thought'.
Also, I drilled the holes and mounted the winch up. This will be its final mounted position.
I added this mid plate to the underside as well for support. Pic taken before I shmeared my boogers all over it.
All welded up
I was going to go ahead and burn the stinger on, but I think I ended up cutting it too short, so now it'll be too narrow when I notch the tube.
That pissed me off. Royally.
I'm sick of trying to create badass stuff with inferior tools. You have to be a fawking millionaire to do things 'right'. Cutting radii into 3/16" steel with a cutoff wheel = not cool. Overhead welding with an old ass stick welder that doesn't even have a working switch = not cool. Manual bender without bendtech = not cool. Notching tube with a cutoff wheel = not cool.
To complete my setup, I need a 220v mig welder, bendtech, air over hydro kit for my bender, a quality notcher, and a torchmate table.
Its sooo frustrating putting in so much time, only to have mediocre results. It seems my expectations are growing faster than my abilities with the tooling I have available.
I guess this is why I've waited so long to build bumpers. I knew it was going to be a project that I would struggle with.
/rant
