Anybody had ignition lock cylinder problems?
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
649
Central Indiana
Jumped into my 01 after work today and the key wouldn't turn. I messed with it quite a bit and couldn't get it to budge. Using some very basic tools that I happened to have on me, I was able to remove the lock cylinder completely, and eventually free it up enough to turn the truck on when it was reinstalled. There's a little spring loaded tab/detent near the bottom of the cylinder that can be pushed in while turning it to free it up.
Replacing the lock cylinder is the easy button, but then I'd have separate keys for the ignition and door locks which I'd like to avoid. I'm also not sure if a replacement ignition key would even work on my 01 since it looks like it has a security chip on the bottom of the column directly under the key switch. Anybody ever repaired a lock cylinder successfully? I think I'll give it a try on my next day off.
Until then, I drive the racetruck to work :3gears::3gears:
pjtoledo
2,979
Toledo Ohio
Fords
3.0 2.3
if the pins get gummed up they won't retract. acts like the wrong key is being attempted.
let me re-phrase that:
if the pins get gummed up they will stay pushed back as far as the largest bump on the key, will not spring back and follow the contour.
drlewistwo
Not on the ranger, but my wife's Saturn. New lock, rekeyed in my kitchen. Not too hard to do
Sent from my SM-N920T using Tapatalk
black_demon69
142
AZ
4.0l
you could just remove the lock cylinder from truck and take to a locksmith to be rekeyed i would also have them check your key for wear . you could also lubricate the lock cylinder. www.triflowlubricants.com
i believe you can get it at ace hardware
Mightyfordranger
156
Ohio
3in
Clean your room before you criticise the world.
Id just try and clean up the lock cyclinder as long as there's no sensors in it to get ruined. Ya know little blaster wd-40 mix or sumthin sit in a coffee can for a day or so. Little air compressor action on it. Whatevers clever
Sent while eating tacos
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
Good subject. The Rat's key barely works. The Rat sits a lot. How much of a chore is R+Ring the cylinder? I just did a Schlage dead bolt and I've re- keyed a BMW core. I like the idea of giving the cylinder a bath in a can of cleaner then a little oil. Are there any plastic bits that will get eaten by a solvent? TIA :D
black_demon69
142
AZ
4.0l
No plastic bits to harm just remove and clean with brake clean and lubricate with either tri-flow or a silicone spray lubricant NOT Wd40.. then reinstall
