99 Ranger V8 swap and manual to auto conversion
8,374
XL2T-14B205 is the GEM module
X = 1999
L2 = Explorer
14B205 = Generic control module, basically the "Body Computer"
1995 to 2000 Rangers used the GEM as the 4WD Controller, so there are different GEMs if course
1998-2000 Rangers also used GEM for speed calibration
stretchstick
13
Colorado Springs
Good information, thank you.
So, with transferring the Mountaineer engine harness and cab harness into the Ranger, will the Ranger GEM be compatible with said harnesses?
franklin2
1,775
Virginia
Bronco II
Is there a reason not to use the Mountaineer GEM?
stretchstick
13
Colorado Springs
All I know is the Mountaineer harness does not have transfer case controls since it was all wheel drive.
Been questioning this ever since the idea of using the Mountaineer harness came up. I have to find out how the controls for the Ranger transfer case will adapt into the Mountaineer harness.
Josh B
1,988
Oklahoma
I like the 1354, and unless the new engine sets it back or changes elevation, seems what you have in it should still work fine.
My 93 had 210ak on it in 2006 when I bought it and now it has over 400, and never a hint of problems from the TC.
It suits me fine just to reach up there and push that button. My initial experience with a 4x4 was hammering and tugging on the front hubs in the freezing cold while trying to get them unlocked and working
stretchstick
13
Colorado Springs
Good to hear another positive about the 1354. Now I just need to know how the Mountaineer wiring will control the 4x4 functions. Not finding anything out there about the issue.
rubydist
869
Denver
Ford Ranger FX4
The Mtnr wiring will not control the 4x4 functions as all the V8 Mtnr were awd with no transfer case controls. If you want to use the Mtnr wiring, you will need manual control of the transfer case.
Josh B
1,988
Oklahoma
This is listed under 99 Mountaneer
Transfer Case
Motor, Electric Shift
The externally mounted transfer case shift motor (7G360), located at the rear of the transfer case (7A195), turns the shift cam assembly. As the shift cam assembly turns, it positions the reduction shift fork (7289) for desired transfer case operation. An integral position sensor in the shift motor provides motor position information to the generic electronic module (GEM).
Switch, Rotary 4x4 Mode
The rotary 4x4 mode switch, mounted on the instrument panel, allows the operator to select the 4WD Auto, 4WD High, and 4WD Low transfer case operating modes. The indicator light, above the rotary switch dial, will illuminate when the 4WD High or 4WD Low position has engaged.
Switch, Brake Pedal Position (BPP)
The brake pedal position (BPP) switch is located on the brake pedal. The switch signals the GEM when the operator activates the brake pedal.
Switch, Clutch Pedal Position (CPP)
The clutch pedal position (CPP) switch is located on the clutch pedal bracket. On vehicles equipped with a manual transmission (7003) and an electronic shift transfer case, the clutch pedal must be fully depressed and vehicle stopped in order to make a range shift from HIGH to LOW, or from LOW to HIGH.
Sensor, Digital Transmission Range (DTR)
The DTR sensor is located on the outside of the transmission near the transmission shift cable attachment. The DTR sensor completes the start circuit in PARK and NEUTRAL, the back-up lamp circuit in REVERSE and the neutral sense circuit (4WD) in NEUTRAL. The DTR sensor also sends a digital output signal to the powertrain control module (PCM) (12A650) indicating the manual lever position (P, R, N, D, 2, 1).
Sensor, Throttle Position (TP)
The TP sensor is located on the throttle body. The sensor provides throttle position information to the PCM. The PCM converts the throttle position signal to a pulse width modulated (PWM) signal, and sends it to the GEM to control and adjust the transfer case clutch duty cycle.
Sensor, Front and Rear Output Shaft Speed (OSS)
The externally mounted OSS sensors are located at the rear of the transfer case. The sensors provide the GEM with front and rear driveshaft speeds to control and adjust the transfer case clutch duty cycle.
Sensor, Vehicle Speed Sensor (VSS)
The Anti-Lock Brake System (ABS) provides the GEM with vehicle speed information to control and adjust the transfer case clutch duty cycle.
Generic Electrical Module (GEM)
The GEM controls the operation of the transfer case in response to inputs from the electric shift motor, 4x4 mode switch, CPP switch, BPP switch, DTR sensor, throttle position output from the PCM, front and rear OSS sensors, and the VSS.
Electronic Shift Control System Components
ItemPart NumberDescription
17G360Transfer case shift motor
27F293Front output shaft speed sensor
37F293Rear output shaft speed sensor
4Shift range selector switch
514B205Generic electronic module (GEM) (electric shift only)
6Digital transmission range (DTR) sensor
Mechanical Operation
The Borg-Warner 44-05 transfer case is available in the Explorer (A4WD) vehicle. The transfer case transfers power from the transmission to the rear axle, and also to the front axle when electronically activated.
In the Auto mode, torque from the transmission is transferred to the input shaft (7017) which, in turn, drives the rear output shaft (7061) that drives the rear axle assembly (4006). The electromechanical ball ramp clutch assembly drives the drive sprocket (7177) after the GEM activates the clutch coil. The drive sprocket turns the drive chain (7A029) that rotates the front output shaft and the front driveshaft (4602). In the 4x4 High mode, the operation is the same as in the Auto mode, except that the GEM consistently activates the electromechanical ball ramp clutch assembly.
The high-low shift occurs when the reduction shift fork moves the high-low collar (7100) to lock the planetary gear set to the output shaft. Then, torque, transmitted through the sun gear, from the input shaft, turns the front planetary gear set assembly (7A398). The front planetary gear set assembly, which is now engaged, provides transfer case speed reduction.
Transfer Case Functions
There are three transfer case modes, Auto, 4WD Low, and 4WD High. Neutral is only available as a dealer installed option.
Control-Trac Function
The Control-Trac transfer case uses an electromechanical clutch assembly to control torque to the front wheels. In the Auto mode, while at rest and under cruising conditions, the GEM activates the transfer case clutch at a minimum level. This allows for the slight difference between the front and rear driveshafts which occurs normally when negotiating a corner on dry pavement. Under any of the following conditions, the GEM will increase the torque sent through the clutch to the front wheels in order to prevent or control slip.
  • Slip is detected (by monitoring the front and rear OSS sensors in the transfer case)
  • Throttle position (by using the throttle position signal from the EEC)
Range Function
NOTE:
At zero throttle, the duty cycle remains low. At very light to heavy acceleration, the duty cycle jumps to the maximum.
In the 4WD Low Range, with throttle input, the transfer case electromechanical clutch locks the front and rear driveshafts for maximum 4WD traction. The transfer case shift motor rotates the shift cam to move the reduction shift fork to the 4WD low range position. This low range shift, accomplished through a planetary gear set, changes the torque to the driveshaft from 1:1 to 2.48:1 ratio.
In the 4WD High Range, with throttle input, the GEM signals the transfer case electromechanical clutch to lock the front and the rear driveshafts for maximum 4WD traction. Never use the 4WD High range when driving on dry or merely wet pavement. Use the 4WD High range only for driving off-road or in severe winter weather.
Josh B
1,988
Oklahoma
I have one for the 99 Explorer/Mountaineer but cannot get it to paste here
scotts90ranger
4,499
Dayton Oregon
2.3 Turbo
I thought the transfer case controller was separate? Did it get integrated?
The 4406 and 1354 are very similar in function, my Explorer (manual 4406) and Ranger (manual 1354) shift the same assuming you ignore the auto trans on the Explorer and manual on the Ranger. they both shift just fine between 4x2 and 4x4 high and back without doing anything dumb, assuming I shift to neutral I've gone from low to high on both just fine with the normal clinky clanking (don't make that one a habit). The 1354's don't have a bad reputation but I wouldn't pay more money to run a 1354 over a 4406...
franklin2
1,775
Virginia
Bronco II
From the description above, it sounds like the Mountaineer is not a true "AWD" in the sense most people think. The electronics are controlling the transfer case to make it "look" and "act" like AWD in certain modes. My Tahoe works like this. I never use the "auto" function, I feel like it's too much wear in the transfer case clutch.
I would use the mountaineer transfer case and drive on. Sounds like it would work for your purposes when you needed 4x4 in the pickup.
fastpakr
2,849
Roanoke, VA
The V6's part time case may function that way, but the V8 gets a true AWD case with no external controls whatsoever (and no low range).
franklin2
1,775
Virginia
Bronco II
So he can use the mountaineer GEM with no problems? Use the mountaineer GEM with a manual lever transfer case?
fastpakr
2,849
Roanoke, VA
At first glance I don't see why not? But I defer to people that know better.
You'd need to splice a couple of wires to make the 4wd lights work on the dash.
